Steering Stabilizer - JeepForum.com
post #1 of 37 Old 10-22-2014, 04:33 PM Thread Starter
BlackJeep2013
Steering Stabilizer
Hey all I have a question. What is the best upgrade to the stock steering stabilizer on 13 Wrangler Rubicon 2 DR? I ask because our jeep is a little squirrely at times. It has Rubicon express 2.5 lift and 285 tires added. Had a alignment done it was off a little bit not too bad, loosened all control arms re-torque to factory specs and it got a little better but was thinking if I was to put a better quality stabilizer on her it would be even better. Thanks for any input.
BlackJeep2013 is offline
post #2 of 37 Old 10-22-2014, 04:37 PM
jpin321
jpin321's Avatar
2015 JK Wrangler
Steering stabilizer isn't the answer. Sounds like your caster is off. Did the alignment shop give you a print out of your alignment?
"Anyone who has never made a mistake has never tried anything new." ~Albert Einstein
My Jeep History -- 1980 CJ5 > 2005 TJ X> 2013 JK Sport> 2015 JKU Rubicon > ?
jpin321 is offline
post #3 of 37 Old 10-22-2014, 05:40 PM Thread Starter
BlackJeep2013
Yes
post #4 of 37 Old 10-22-2014, 05:44 PM
jpin321
jpin321's Avatar
2015 JK Wrangler
Awesome. Do u have the ability to post up your results? Might be helpful to determine if it really is a caster issue.
I had the exact same issue after installing my aev lift. Installed the control arm drop brackets and all was well.
jpin321 is offline
post #5 of 37 Old 10-22-2014, 07:59 PM Thread Starter
BlackJeep2013
Ya I think its at home. I'm on 24 hour duty right now so I'll have to check it tomorrow and try to post it up here. Thanks for the heads up.
post #6 of 37 Old 10-22-2014, 08:20 PM
jpin321
jpin321's Avatar
2015 JK Wrangler
Also make sure your not running too much tire pressure. That will make if feel a little loose as well. If you can post up your current pressure we can help with that as well.
jpin321 is offline
post #7 of 37 Old 10-22-2014, 08:24 PM
HappyTrails
HappyTrails's Avatar
Look up "Chalk Test" and adjust your tire pressure that way.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #8 of 37 Old 10-22-2014, 10:10 PM Thread Starter
BlackJeep2013
Well since I moved up to a 285 tire size I don't run the 37 psi, I run 33 psi in them. When I ran them at 37 it was almost horrible to drive.
post #9 of 37 Old 10-22-2014, 10:32 PM
HappyTrails
The larger the tire, generally, the lower the tire pressure.
I.E.: I run 27 psi in my 37's. But that is based on my individual Jeep considering weight, and wheel size. I used the chalk test to determine that psi.
But like jpin321 said, a steering stabilizer is not the answer. Adjusting tire pressure or the castor on the front lower control arms is where you need to start. Many people drive without a steering stabilizer. It is really only necessary when you get to the very large tire sizes (37"+) to stop bump-steer. Personally, I run without one.
post #10 of 37 Old 10-23-2014, 12:38 AM Thread Starter
BlackJeep2013
You know know that I think about the lift kit I do remember two round disk looking items and wonder if that's for caster adjustments. I need to look up install instructions and see.
post #11 of 37 Old 10-23-2014, 12:46 AM Thread Starter
BlackJeep2013
Yep sure as sh--. These dang things
post #12 of 37 Old 10-23-2014, 02:33 AM
zjilla
zjilla's Avatar
SS is not the answer but when I switched from 35s to 37s (36.5ish) i could feel more road movement in the steering wheel when driving straight(not enough to call it bump steer-just enough to tell that my tires got bigger) so I swapped out the stock SS for a rancho one and it improved a little bit. try dropping your tire pressure to 30 or below and see if that is the difference.
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
post #13 of 37 Old 10-23-2014, 07:29 PM Thread Starter
BlackJeep2013
Pic of alignment print out
post #14 of 37 Old 10-23-2014, 07:33 PM
JDePietro
JDePietro's Avatar
2005 WK
Watching this one like a hawk. I have a Zone 3" and up until I put 35's on everything was fine. Now it rides like crap and follows every rut in the road. Was going to get a new track bar but after reading some threads over the week I'm thinking its more of an alignment issue.
Man's got to know his limits.
JDePietro is offline
post #15 of 37 Old 10-23-2014, 07:39 PM
jpin321
jpin321's Avatar
2015 JK Wrangler
Someone can correct me if I'm wrong. But you're at about 3*, stock is around 4* - 4.5* I think. I believe you would really benefit from some caster adjustment to get you closer to stock. I wouldn't use the cam bolts personally. If I were you I would opt for drop brackets like from aev http://www.aev-conversions.com/shop/...n-brackets-frt (this is what I have) or best case but more expensive would be some lower adjustable control arms.
My aev 2.5 lift netted me 3" of lift mine drove like a complete crap. The addition of the AEV brackets made all the difference. The added bonus to the drop brackets is it actually softens up the ride a bit by leveling out the control arms.
jpin321 is offline
