Steering issue!! Help! - JeepForum.com
post #1 of 10 Old 09-06-2019, 07:37 PM Thread Starter
mbowlin
I have 2008 4 door jk with a 3.5 inch rough country lift , I just updated all new ball joints , tie rods , and put in a high steering kit ! Alignment was done today and the steering will not come back to center , you have to fight it to stay straight down the road and when you turn it won’t come back on it’s own ANY IDEAS , oh new steering gearbox as well !
mbowlin is offline
post #2 of 10 Old 09-06-2019, 09:38 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
It's likely that the ball joints are tight and need to get worn in. I had that problem with one set and was told that it could take as much as 500 miles before they feel good. I couldn't wait that long so I replaced them again with a differant brand, I think Poly Performance or Teraflex, and they were great from day one.
Jim
JLC08JK is offline
post #3 of 10 Old 09-07-2019, 12:28 PM Thread Starter
mbowlin
I have Teraflex ball joints n about 1000 miles on them if not more
mbowlin is offline
post #4 of 10 Old 09-09-2019, 02:34 PM
cranbiz
cranbiz's Avatar
Sounds like the toe isn't set right. Should be 1/8" to 1/4" toe in.
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #5 of 10 Old 09-09-2019, 09:38 PM Thread Starter
mbowlin
Had a complete alignment done this past Friday , didn’t change a thing , I’m at a loss right now !
mbowlin is offline
post #6 of 10 Old 09-10-2019, 09:28 AM
cranbiz
cranbiz's Avatar
Post the print out of the alignment. You could also have geometry issues.
There can be a lot of things causing this, I just don't know right now.
06 KJ
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #7 of 10 Old 09-10-2019, 02:03 PM Thread Starter
mbowlin
The steering wheel clock spring is bad that’s the problem!!
mbowlin is offline
post #8 of 10 Old 09-10-2019, 03:18 PM
cranbiz
cranbiz's Avatar
That's a good thing, that's under an extended warranty.
Usually when the clockspring goes bad, you get all sorts of dash lights but I'm happy you got it figured out.
Steering wheel get turned while the steering box was being replaced? Please don't ask me how I know about that one.
06 KJ
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #9 of 10 Old 09-10-2019, 10:10 PM Thread Starter
mbowlin
Thank you ! 👍
mbowlin is offline
post #10 of 10 Old 09-10-2019, 10:24 PM
222Doc
222Doc's Avatar
sounds like new parts that need break in and be sure to grease those when installed and every 3k. Unless you have real low caster numbers. what is your caster angle? not enough and it wont return to center anyway. did you add a Dc drive shaft and rotate the front to parallel? That will toss the caster numbers into the positive when they should negative. That will cause over steer. will want to turn. and about create wobbles in the end.
you did the work?
222Doc is offline
