Steel wheels for a JKU - JeepForum.com
post #1 of 3 Old 03-29-2018, 12:37 PM Thread Starter
P NUT
Hey fellas, I'm looking for some steel wheels for JKU (Sport). Not the typical Procomp and etc, but kind of ones you see on stock vehicles. I've searched around on typical sites and Google, but I'm unable to find any. Please see the picture below for reference. I'm looking to build it out with Old School in mind. Size wise, I'd prefer 17's. If 16's fit, I can work with that as well. Tires: I'll probably stick with 255/75/17 size, or maybe 285/70/17, but won't go wider or taller than that.
If you could tell me where I can find some like these. Or, do steel wheels from other Jeeps fit? Thanks.
P NUT is offline
post #2 of 3 Old 03-29-2018, 02:18 PM
BlueBabySound
2018 JK Wrangler
We used US Wheel on the '18 Build (pic below), ours is the Rat Rod series but they have several other series too. https://www.uswheel.com/
There is also Wheel Vintiques.
BlueBabySound is offline
post #3 of 3 Old 04-03-2018, 12:18 PM
LouC
2007 WK
if 16s will work for you the JKU sport comes with decent looking styled steel wheels that come silver but you could paint them any color you want. Tthe other option is a Mopar steel wheel used for the spare on some WKs, it is a 17x8 i believe and is similar to your first pic above. Same bolt pattern as the JK (5 on 5) not sure if the offset is the same. I have a set on mine for the winter with snow tires. They are hub centric so they will fit perfect and not cause balance issues that you sometimes have with lub centric aftermarket wheels.
Second pic is the standard JK 16" steel wheels....
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
