Soft Top Stretch - JeepForum.com
post #1 of 17 Old 08-01-2010, 05:39 PM Thread Starter
ramath0294
Soft Top Stretch
Does Anybody have this problem I have a 2010 4dr JK and when we take the back and side windows out. The rear pilars always pop out of there track from normal around town driving its kind of a pain it seems that the have scretched in this location other then this the top has been perfect no issues the jeep only has 3k miles so i dont want it to get worst....Any help would be awesome....
ramath0294 is offline
post #2 of 17 Old 08-01-2010, 06:18 PM
DeepSky
DeepSky's Avatar
If I understand you correctly you are saying that the rear door surrounds get pulled out of their resting spot on the tub rail when you have the back and side windows out? Or are you saying that the rear sail panels in the very back pop out of the tub rail & plastic clips?
EDIT: Welcome to the forum BTW.
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #3 of 17 Old 08-01-2010, 07:28 PM
jbco
2009 JK Wrangler
I think he is referring to the sail panels. If that is the case, they should not be popping out of the track. You should still be under warranty with a 2010, have the dealer fix or replace it for free.
jbco is offline
post #4 of 17 Old 08-01-2010, 08:27 PM
itasor
itasor's Avatar
2009 JK Wrangler
Does the 2010 soft top frame click in above the door surrounds? I know if I don't have my 2009 frame clicked in above each door surround, there isn't much pressure on the sail panels and they easily come out. Once clicked in though, they stay in even at highway speeds.
itasor is offline
post #5 of 17 Old 08-03-2010, 03:53 PM
Jos360
2010 JK Wrangler
The 2010 has on both left and right side above the middle crossbar (just above your head) a clip that your soft-top frame should click into. If that is clicked together well and the rear soft pillar still pops out of the tub, there is something wrong. I've never had that happen and it seems pretty hard, as the softtop is still pretty tight on there.
2010 Jeep JK Unlimited. Sahara, 6spd manual, Deep Water Blue.
Jos360 is offline
post #6 of 17 Old 08-03-2010, 04:02 PM
ncb
ncb's Avatar
Are the nylon straps loose from the last bow?
ncb is offline
post #7 of 17 Old 08-03-2010, 05:48 PM
JeffinWesternWA
2010 JK Wrangler
MURDER of the Queens english here...wh'ad he say????
JeffinWesternWA
JeffinWesternWA is offline
post #8 of 17 Old 08-11-2010, 11:13 PM Thread Starter
ramath0294
I am ref to the rear sails that pop out all the time (top half down) , (top full ) but only if the windows are all down and all zipped if i leave the rear window in and roll it up its a lil better but is very flappy.I do notice it more on smoking hot days but when i look at older jk not sure what year its not as bad as mind. I am almost + that when he went over the truck he said the top was not under the warr. like the rest of the truck he said it falls under like tires,brakes,top. I could never go out on (95) or highway deff would pop out and flap in the wind looks terr gets on my nerves... I need to stop by the dealer later on i hate dealing with them . Its only 5 weeks old
post #9 of 17 Old 08-12-2010, 05:41 AM
krutj
krutj's Avatar
2009 JK Wrangler
That is BS.........
Mine was sewn poorly from the factory, replaced under warranty.
Your dealer doesn't know crap....I don't think that I'd have much confidence in a dealer like that.
-- Joel --
krutj is offline
post #10 of 17 Old 08-12-2010, 06:01 AM
BigRed09
2009 JK Wrangler
my sail panels flap like crazy but they dont pop out. mine's got 13k miles, have driven it up to 80 mph down the the beaches, down to myrtle beach, and on 95 quite often and they havent come out. your dealer doesnt know anything at all, take it back and make them fix it.
Mods so far: Mastercraft handles front and rear, Rugged Ridge euro rear tail light guards, Rugged Ridge mirror movers.
BigRed09 is offline
post #11 of 17 Old 08-12-2010, 08:39 AM
ncb
ncb's Avatar
The sail panels hold at highway speeds on my Jeep. I no longer get on the highway with the rear windows out after seeing how bad they flap. Your sail panels are too long or the wide nylon straps that attach to the rear bow have pulled from the rivets or are too long. You should have a good amount of tension on the nylon straps.
ncb is offline
post #12 of 17 Old 08-12-2010, 08:43 AM
c6bix
I like the look
Nice
c6bix is offline
post #13 of 17 Old 08-12-2010, 09:32 AM
ncb
ncb's Avatar
Originally Posted by c6bix View Post
Nice
Say what?
ncb is offline
post #14 of 17 Old 09-08-2011, 01:55 PM
Brmelissa
I am having the same problems with my sail panels. If I have the top half way down & all windows out, then the sail panels will pop out of the track. So irritating & embarrassing, I have to stop on the side of the road to fix. Usually when driving over about 45mph. So is there something wrong that the top needs to be replaced?
Brmelissa is offline
post #15 of 17 Old 09-08-2011, 03:41 PM
Celtic
2011 JK Wrangler
Ramath,
I did not see your reply to itasor. Are you sure the top is clicked in to the top of the door frames? If it is not clicked in properly on both sides, there will not be enough tension on the rear bow to hold the sail panel clips securely under the body lips on the rear corners. This would be most noticeable when the only the front of the top is folded halfway back (Sunrider position?).
Celtic is offline
JK Wrangler , pulling out , sail panel , soft top , wrangler
soft top won't stretch, thus won't fit...HELLLLLLLP! lol E-Poppa YJ Wrangler Technical Forum 23 08-17-2009 06:10 PM
Clayton's long arm and 5" stretch or the double triangulated with the stretch? Haz-Mat TJ Wrangler Technical Forum 14 08-14-2009 07:44 PM
Stretch YJ Jeebs Wrangler General Discussion 22 12-19-2008 10:48 PM
anyone tried the clayton stretch kit or a custom stretch setup bluejeep2088 TJ Wrangler Technical Forum 5 02-01-2007 08:04 PM
