Shock help for RK xfactor 3.5" lift - JeepForum.com
post #1 of 9 Old 11-15-2015, 09:05 PM Thread Starter
mrdeezus
Hey, I'm getting the mid arm RK Xfactor 3.5" lift and I'm going with the Fox res shock(non adjuster) and I've been reading that its better to go with a 4-6" lift shock with this kit, anyone have an opinion?
Thanks
mrdeezus is offline
post #2 of 9 Old 11-24-2015, 01:37 AM
HOKIES2010
HOKIES2010's Avatar
2011 JK Wrangler
Have you called RK and asked them for shock lengths? I also think I remember seeing the advised lengths posted on thier site.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #3 of 9 Old 11-24-2015, 10:03 PM
HappyTrails
HappyTrails's Avatar
I have no experience with the res. Fox shocks, only the Fox 2.0's.
With Fox, you want to go with the longer travel shocks. I believe I used the 4-6" lift length Fox 2.0 shocks on mine.
Jason @ KrawlOff-Road should chime in here and advise.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #4 of 9 Old 11-25-2015, 12:50 AM
HOKIES2010
HOKIES2010's Avatar
2011 JK Wrangler
I am runnng their 11" travel RRDs on my 3.5 RK lift
My Build
post #5 of 9 Old 11-25-2015, 08:14 AM
KrawlOff-Road
Thanks guys!
First, if your going to run a RK 3.5" I would recommend going to the 3.5" X Factor. The Mid Arm has just the front and rear lowers. The X Factor steps up to all 8 arms. This will greatly help the pinion angle front and rear so your drive line will thank you. Also, it will move the rear axle back 1" to re-center the wheels in the wheel wells. It is a much better all around setup for the 3.5" height. I would also budget for a new front shaft if you are going to plan on wheeling it:
http://www.krawloff-road.com/product...aftjkfront.htm
Now for the original question. Yes, you would want the longer shocks. I would do the 4-6" length. Heck, that is the length we run on our 2Dr with a RK 2.5". You will be fine and your RK coils will use every bit of it!
Feel free to PM, email, or call us and we can help you get setup! We have some SMOKING deals right now... of course. Just let us know how we can help!
-Jason
KrawlOff-Road is offline
post #6 of 9 Old 11-29-2015, 12:09 PM
Tjosh97
I'm gonna have to pm Jason thinking this is the kit I want:
http://www.krawloff-road.com/product...jk35xf-kit.htm
With Fox! Is that a good setup Jason?
Tjosh97 is offline
post #7 of 9 Old 11-29-2015, 02:51 PM
Tjosh97
So for a 3.5 Rock Krawler lift....it's better to have a 4-6 lift fox 2.0 performance shock?
Tjosh97 is offline
post #8 of 9 Old 11-30-2015, 11:09 PM
mdrums
2017 WK
A RK 3.5 lift is going to be more in the 4.5" lift range. My RK 2.5 gained me al,oat 4" front and 3.5" rear. I'm using the Fox 4-6" shocks no problem with 3" bumps. I also bought them from Jason at KrawlOff-Road and am extremely happy with everything and the advice from Jason.
mdrums is offline
post #9 of 9 Old 12-02-2015, 02:51 PM
KrawlOff-Road
Thank you for the kind words my friend!
And sorry got swamped with the holidays. No worries our sales are still going on for a few more days! BUT, yes, I would do the 4-6" lift height shocks. If you order the lift from us, we will take care of you and get you the correct length shocks for your setup.
-Jason
