JeepForum.com (https://www.jeepforum.com/forum/)
-   JK Wrangler Technical Forum (https://www.jeepforum.com/forum/f96/)
-   -   Ride difference between long and short arms (https://www.jeepforum.com/forum/f96/ride-difference-between-long-short-arms-666729/)
FatBuoy 01-07-2009 05:45 PM
I'm still having my internal debate. It looks like my cost difference between long arms and regular adjustable will be about $500. I've got a buddy who will help install either, so installation cost on the LAs would be minimal. Who out there has experience driving both setups both on and off road? I understand the more articulation aspect, but is there a huge difference on the pavement in regards to ride quality? I will be going to 37s eventually, but will keep the lift at 4" with different fenders for clearance if that makes any difference.
Thanks!:cheers2:
HITMONEY 01-07-2009 05:56 PM
Physics say the LA will ride smoother.. now whether or not it will be enough to notice in the drivers seat is another question since the JK already has pretty long arms to begin with.. kinda like mid length arms.
The more parallel your control arms are to the ground the less shock, or jarring, is transmitted up into the body but rather dissipated through the vertical movement of the control arms... this of course is not counting the harshness of your shocks.
EDIT: But IMO my LA rides every bit as smooth if not smoother than it did stock and definitely smoother than some other lifted JK's I've ridden in. The only one that is noticeably smoother that I have experienced has been a RE LA.
themaniam1 01-07-2009 11:41 PM
Ok I feel that I can speak from alot of experience here. The LA will ride much smoother then a SA of 4" or greater. I have had three wranglers with short arms and then upgraged to long arms and the results were the same each time, wow they ride smooth. My wife infact will not have anything but long arm lifts. Our TJs went from bumpy and a little scary on the highway to smooth and no worry driving. We went right from factory to LA with our JK and the same thing, smooth and no worries. They wheel just awesome on the rocks with great travel and articulation. In some situations they will scrape on the rocks but I have yet to every regret getting them. For $500 more I would not even hesitate. They even look good too.
http://lh3.ggpht.com/_IMKnUj6I0Eo/SW...0/IMG_3213.JPG
Xtremjeepn 01-08-2009 10:06 AM
On a TJ it makes a big difference. Much less on a Jk. Having experience On a tj is not relevant unless you have done both on a jk? Different animal.
Prot 01-08-2009 12:07 PM
I hear great things about the Rubicon Express kit. If I were starting over, I think I probably would have went that route. Granted, it's a lot more than my basic black diamond kit.
scrogg 01-08-2009 01:13 PM
I went from a TeraFlex 4" short arm to a TeraFlex 6" long arm with my JK and the difference is very noticable. The on road mannerisms of the LA are superior to the SA. The ride is smoother and the vehicle feels more stable than previously. And the body roll even seems to be less than what the 4" springs allowed, not sure if the LA's have anything to do with that or not.
I feel confident traveling down the freeway a 70+ mph with the LA's. The short arms gave me the feeling that I had to hold onto the steering wheel, even though I could let go and it still drove straight. The LA's seem to transfer feedback from the surface to the steering wheel in a far better manner than the SA's did.
One another note, when I first had the swap done it felt so different just going through the gutters in the neighborhood. It's hard to explain but it felt way cooler. After talking with Carl at TeraFlex Plus, he explained that it was probably due to the angle of the LA's vs the SA's. The SA's were at a steep enough of an angle that it was almost jarring as opposed to the LA's.
Amazingly smoother by far is all I can say. I am very pleased that I upgraded and would highly reccommend it to anyone that is seriously considering it.
FatBuoy 01-08-2009 02:41 PM
There seem to be some differing opinions, as there always are, but I think the answer will be LAs. If I heard, "you will not be able to tell a difference on a JK unless you have 2 ft. of lift, don't waste your money" I would say no, but for the $500 it sounds like a good idea now rather than regretting not doing it later.
Thanks again Jeep gurus!:thumbsup:
HITMONEY 01-08-2009 03:20 PM
It is WELL worth the extra $500.00.
The time now is 12:05 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
