Regear Speed change - JeepForum.com
post #1 of 4 Old 01-08-2009, 01:54 PM Thread Starter
towerassoc
towerassoc's Avatar
Location: Prescott,AZ Summer, Sun City West, AZ winter.
Regear Speed change
I have a 2008 X with 44 rear and 30 front, 285/70/17 tires, 2.5 BB and 3.73 gears, Auto.
I would like to regear to 5.13 but would like to know what the speed o meter change would be around 60 miles per hour.
I searched for a chart but could not find one.
Tanks
Bill
towerassoc is offline
post #2 of 4 Old 01-08-2009, 02:39 PM
tricked919
Tanks
Bill
wow - 5.13's for 285/70's ?? Isn't that smaller than a 33 ??
As far as answering you question, I believe the change is strictly based on the change in tire size because the speed pick up is tied in with the ABS wheel sensors. Dealer can calibrate that up to 32" I think, but I've never heard of a speedo change with gears.
Someone will correct me - I'm sure.
tricked919 is offline
post #3 of 4 Old 01-08-2009, 02:41 PM
Prot
Prot's Avatar
2014 JK Wrangler
That's 32.7" diameter. That's not much bigger than stock.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #4 of 4 Old 01-08-2009, 03:31 PM
08BlueSahara
08BlueSahara's Avatar
So, you'll either need to have the dealer program it to 32" (and still be slightly off), or use an aftermarket programmer like:
https://www.jeepforum.com/forum/showt...eedo+reprogram
08BlueSahara is offline
post regear fluid change kllrbee TJ Wrangler Technical Forum 4 01-26-2010 05:19 PM
Regear or 6 speed swap? jgorm TJ Wrangler Technical Forum 12 08-17-2009 06:43 PM
What speed OK to change from 2wd to 4wd? strategydude JK Wrangler Technical Forum 26 07-31-2008 02:47 PM
Would it be worth it to change out my d35 rearend or should I just regear? asw613 YJ Wrangler Technical Forum 6 04-30-2008 06:03 PM
Speed change dieselcrackel TJ Wrangler Technical Forum 7 08-17-2006 09:07 PM
