Rear wiper issue....need help - JeepForum.com
post #1 of 7 Old 12-24-2012, 01:33 AM Thread Starter
Ray96
2011 JK Wrangler
I just installed the hard top wiring harness kit to my 2011 Wrangler Unlimited, and although the rear wiper is functioning, it's pausing in mid-cycle (won't even complete 1/2 of the full up-down cycle without pausing). The pause lasts for about 5 seconds, then the wiper will move a little more before pausing again. Any thoughts??
The rear washer spray and all other functions seem to be working fine.
Thx,
Ray
Ray96 is offline
post #2 of 7 Old 12-24-2012, 02:06 PM
durango-bob
durango-bob's Avatar
2006 WK
I'm not sure what the problem is, but it kind of sounds backwards. The 5 seconds time should be when it runs and the short times when it waits for the next run pulse to make a full swipe.
durango-bob is offline
post #3 of 7 Old 12-24-2012, 03:09 PM
ncb
ncb's Avatar
I believe the computer needs to be flashed after the harness is installed.
ncb is offline
post #4 of 7 Old 12-24-2012, 03:18 PM Thread Starter
Ray96
2011 JK Wrangler
Thank you, I will try that.
Ray96 is offline
post #5 of 7 Old 12-24-2012, 03:28 PM
xtremzj
Yep it does. BUT if the jeep came with a hardtop from the factory it dosent.
We have had a problem with these harness'. On wranglers (opposed to other models) in the dash there is little tabs in the harness connectors that are called ground tabs. For whatever reason some of the ground tabs break or get bent. When that happens you don't have ground for that 1-2 seconds to that motor.
I know this the hard way. We called Chrysler and after several attempts to figure it out over the phone, we had a Chrysler electrical engineer steer us in the right direction. That jeep was in the shop for days. Ugggg. Memories...
98 ZJ 5.5in hybrid long arm/35"TSLs/4.7 Golen Stroker/Kevin's front bumper/TrailReady rear/hp30/d44/4.56/oba/dual battery/rocklights/milemarker9k.Way to much to list.
QuirkWorks Sponsored #44 subaru rally car
CHRYSLER CERTIFIED MASTER TECH. PM IF YOU HAVE QUESTIONS.
xtremzj is offline
post #6 of 7 Old 12-24-2012, 04:23 PM Thread Starter
Ray96
2011 JK Wrangler
It did not come with a hard top -- I just bought one a few weeks ago. I'm hoping it's just a matter of reflashing. Do I need to take it to a dealership or is that something that I can do at home?
Ray96 is offline
post #7 of 7 Old 12-24-2012, 04:27 PM
xtremzj
It needs to be taken to a dealership
xtremzj is offline
