Rancho Leveler springs added to Rubicon- pics - JeepForum.com
post #1 of 3 Old 04-13-2008, 10:29 PM Thread Starter
SargeW
SargeW's Avatar
2018 JK Wrangler
After adding some goodies to the front of the Jeep, I dropped the rake another 7/8 inch from what the factory had delivered. In this pic you can see the Blue Ox tow plate to allow me to flat tow the Jeep behind the Motorhome, and Rough Country winch plate holds the Warn Ti9500, all of which weighs in at a little under 200 pounds.
I took some careful measurments before I started adding stuff, because I wanted to know just how much each of the mods were going to compress the suspension. This is what it looked like after all three of the mods were added.
After the install of the Rancho springs I checked the measurments. I not only got back the 7/8 inch that the mods had caused, but picked up about 1 3/4 inches to boot. That was enough to level out the rake that the Jeep came with, and even gave me about 1/4 inch more in the front than the rear.
The ride feels a little better than stock, although that could just be feeling of riding level instead of raked. There are no phantom bumps or grinds, and all the factory traction programs are all still happy. The springs were reasonable about $129, and the factory shocks are still being used quite effectively. It I wear them out eventually, I will go with a longer shock, maybe a Rancho RS5000 or the like.
Sarge
Starting over to BOMB the Rubicon......
"Life is hard. It's harder if you are stupid".
SargeW is offline
post #2 of 3 Old 04-14-2008, 08:19 AM
Little Green
Little Green's Avatar
1991 FSJ Wagoneer
Did you install them yourself and how long did it take?
Little Green is offline
post #3 of 3 Old 04-14-2008, 09:37 AM Thread Starter
SargeW
SargeW's Avatar
2018 JK Wrangler
No, unfortunately my house is on the market, so I can't tear down in the garage. I have to be able to leave at a moments notice. The local shop that did it though did it in about 1 1/2 hours. Pretty straight forward, and didn't even need an alignment.
SargeW is offline
Has anyone here added extra throttle return springs? Roach YJ Wrangler Technical Forum 11 08-08-2006 12:36 PM
how do you feel about rancho 2.5 springs on a yj? rsoffar YJ Wrangler Technical Forum 1 04-12-2005 09:59 PM
Swapped out Springs and added BB (Pics) BamaSahara TJ Wrangler Technical Forum 8 03-24-2005 08:24 AM
Rubicon springs before and after (Pics) SoonerYJ TJ Wrangler Technical Forum 44 01-13-2005 08:17 PM
What would happen if I added Rubi springs and a 2BB? unlimited2005 TJ Wrangler Technical Forum 6 11-05-2004 03:25 PM
