My Jeep club is having a wrench-fest tomorrow and we will hopefully be installing a new radiator in my '07 JKU. I bought a CSF aluminum radiator, but it did not come with instructions. The website claims OE specific mounting, "drop-in" fitment requiring no modifications, and CNC machined brackets & fittings. Besides coolant, what else will I need to bring with me? Does anyone know of any write-ups available on-line?
I believe they fail quite often. Mine had multiple leaks. I replaced it today with a CSF all aluminum radiator with two rows for cooling. It would have been easier if my Jeep had a stock air intake, but it wasn't too bad. If I had it to do over again I would have attached the transmission cooler to the radiator before I bolted in the radiator. I would have ordered a radiator cap, because the stock cap was too big. I would have ordered new hoses, because neither Pep boys nor Advance Auto had them in stock.
I believe they fail quite often. Mine had multiple leaks. I replaced it today with a CSF all aluminum radiator with two rows for cooling. It would have been easier if my Jeep had a stock air intake, but it wasn't too bad. If I had it to do over again I would have attached the transmission cooler to the radiator before I bolted in the radiator. I would also have ordered a radiator cap. The stock cap was too big. I would have also ordered new hoses. Neither Pep boys of Advance Auto had them in stock, so I reused the original hoses.
pull the air dam off and the plastic bumper cover off below the grill. you will find the radiator drain on the passenger side on the front of the radiator. you will need a 8mm u-joint 1/4 socket to get the 4 bolts that hold the condenser to the radiator. there are two more 8mm bolts on either side of the radiator. other than that you really don't need instructions or a write up.
Related Threads
Jeep Enthusiast Forums
18.5M posts
727.5K members
Since 2000
