Pro-Rock 44 vs. beef up Dana 30 - Page 3 - JeepForum.com
post #31 of 32 Old 02-17-2012, 02:43 PM
SubAtomicGenius
SubAtomicGenius's Avatar
2011 JK Wrangler
Originally Posted by SlvrJK08 View Post
Notice the part #? It says TJ, that's prolly why it's so cheap.
Don't get fooled with the low TJ prices. Don't think G2 makes a JK axle???
SubAtomicGenius is offline
post #32 of 32 Old 02-17-2012, 06:39 PM
spedly
2011 JK Wrangler
Originally Posted by JLC08JK View Post
From what I've see, the only way to put an ARB locker in a JK D44 is to use Superior Super 44 axles with 35 splines.
I'm not sure what they use in the Dyna Trac 44 when they set it up for an ARB.
edit; I take that back, I just looked it up and ARB has a 32 spline locker just for us
The 35 spline is for the rear.
A non rubi rear 44 can run an standard d44 locker. The rubi front is 30 spline but a different offset so you are still stuck with the 35 spline arb/ox or the oem locker as the only options. If you order a pr44 you can order it to accept a standard d44 carrier. Then you can run whatever you want in it.
I plan to order a pr44 that will fit a standard detroit and a set of 30spline rcv's
Poser Jeep.
spedly is offline
comparison , dana 30 , dynatrac , JK Wrangler , prorock 44 , reviews , wrangler
Rock Krawler 8" triple threat comp coil over YJ kit and Dana 44 front swap questions KennedyYJ YJ Wrangler Technical Forum 0 04-10-2010 02:42 PM
D30 beef up nj95yj YJ Wrangler Technical Forum 5 05-26-2009 01:04 PM
beef up 231 drunkencitywork YJ Wrangler Technical Forum 1 05-11-2009 04:13 PM
Dana 30 Beef sailingdude TJ Wrangler Technical Forum 7 04-19-2007 08:31 PM
Beef ups TEEJAY TJ Wrangler Technical Forum 4 12-21-2005 07:24 PM
