Possible transponder key issues - JeepForum.com
post #1 of 3 Old 11-25-2021, 06:04 PM Thread Starter
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
The battery in my Jeep died. I replaced it with a new battery and as soon as I did the ABS pump came on and wouldn't shut off. I pulled the fuse for the ABS pump and just drove around with the warning light on the dash for 3 days. Then one morning I started it up and on the 3rd crank the starter made a funny noise but the Jeep fired up and ran. I was curious about the noise so I shut it off, and then tried to start it again but nothing happened when I turned the key. So I bought a new starter and installed it, and it still won't start. It doesn't even try to turn over. So I checked all my fuses and relays and everything is good. I pulled the starter solenoid relay and jumped pins 30 and 87 together with a small loop of wire and the starter will engage and turn the engine over. SO I turned my key to the run setting, and cranked the engine over by bypassing the starter relay, but it will just crank away and still won't start.
My question is, how do I know if it's the factory security preventing it from starting? I've gone around the Jeep and locked and unlocked all locks with the factory key, and I'm using the factory key in the ignition switch. From what I've seen online the factory security should get reset when I remove the negative battery terminal. But I have done that several times, and even let it sit unconnected for a few days and it still won't start.
Anyone got any advice or other ideas I can try before I end up having it towed into the stealership?
Thanks in advance!
~Necro~
Necromancer_tat is offline
post #2 of 3 Old 11-26-2021, 03:15 PM
222Doc
222Doc's Avatar
I have disconnected the battery on my 2012 JKR i could not count. To weld on it mostly. Never once has it went into lock out mode. I have had dead battery as well.
I have heard of it happening when people try to start it to many times dead enough it wont start. But even that was somewhat hear say. If its in lock wont that red light that is the security be on. they tend to start then shut off as well i thought?
no codes before or now? you looked.
by chance did you use the 10m nut on the battery cable that tightens the post for anything. If so that might be your issue. adding say the winch Hot there makes that tapper nut not fit and what seems tight is not.
222Doc is offline
post #3 of 3 Old 11-26-2021, 11:50 PM Thread Starter
Necromancer_tat
The little red light on the right hand side of the instrument cluster lights up. I have not pulled any codes. I don't have a code reader. The 10mm nuts on the battery cables have not been used to add anything, they still function correctly.
