Poison Spyder New BFH Rear with Hitch Prototype - JeepForum.com
post #1 of 10 Old 07-13-2015, 03:09 AM Thread Starter
HSKR4X4
I've had this bumper a few months now, and finally got the chance to install the new Poison Spyder Customs BFH Rear Bumper with hitch (I have newborn twins now so everything was put on hold) As of right now it's still a prototype, but I think they will be releasing something soon. The hitchlink 2.0 is made by Factor55 and works perfectly with this new bumper. The install is pretty similar to the original BFH, but you replace your existing crossmember with a new Poison Spyder one that has hitch welded in place. The bumper and crossmember are two separate pieces, but the bumper slides over new crossmember making it look like a one piece design.
I got the ok to share so here is the new prototype bumper!
Thanks to my buddy Jim (That_guy), and Jason at Absolute Offroad for helping with this install! I really appreciate it!
Final Install
This is the new Poison Spyder Crossmember with hitch
Cutting frame and torching out crossmember
Everything got touched up in between photos, which included grinding, welding, painting and just making sure everything was perfect before final install.
GO BIG RED!
HSKR4X4 is offline
post #2 of 10 Old 07-13-2015, 03:59 AM
LeighP
Really? You have to cut out and weld in a crossmember to get a bumper with a hitch....when other companies make bolt on bumper/hitch combinations?
Seems like an expensive and time consuming approach to the problem.
Hey, just my opinion.
Looks nice.
Regards,
Leigh
2013 JK Overland/Sahara 3.6L
LeighP is offline
post #3 of 10 Old 07-13-2015, 06:53 AM
WhiteRavenRR
If you're looking to do cutting without the welding, just go for the JCR Dagger. I went with this bumper over the BFH since it had the receiver at the time.
WhiteRavenRR is offline
post #4 of 10 Old 07-13-2015, 07:10 AM Thread Starter
HSKR4X4
While I do like that bumper, it is wider so running a spare isn't probably an option. With my TeraFlex carrier and 37s, I'm right on the border of it not fitting, so any wider like yours I'd lose the spare
GO BIG RED!
HSKR4X4 is offline
post #5 of 10 Old 07-13-2015, 08:38 AM
JIMBOX
JIMBOX's Avatar
2018 LJ Wrangler
I hope you're not forgetting--
---SAFETY CHAINS---
It's illegal to tow a trailer without --SAFETY CHAINS--
OK--where's the Frame/hitch anchor point ??
They look good though, but---
JIMBO
Firecracker Red 2dr RUBICON--2018
Stinger Yellow 2016 RAM/Hemi/8spd auto 4x4
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #6 of 10 Old 07-13-2015, 08:20 PM
WhiteRavenRR
The safety chain points are tucked up under the bumper. Trust me, it was one of the first questions I had when I called them up.
I run a spare on mine now that I finally got the Teraflex Hinge/ Tire Carrier combo.
post #7 of 10 Old 07-13-2015, 08:21 PM
WhiteRavenRR
The hitch pin is inserted up underneath the bumper as well.
post #8 of 10 Old 07-13-2015, 08:40 PM
JIMBOX
JIMBOX's Avatar
2018 LJ Wrangler
Thanx everso--
Straightened me out like a ruler !
JIMBO
JIMBOX is offline
post #9 of 10 Old 07-14-2015, 07:13 AM
WhiteRavenRR
Anytime JIMBO, anytime.
post #10 of 10 Old 07-14-2015, 11:38 AM
bob6987
Where can i get this cross member? Will it work with my current Poisonspyder BFH bumper i have installed?
1991 YJ, 4.0, 6" lift, 40" tires, full cage, dana44/ford 9, detroit locker, 5.38 gear
2012 JKU
bob6987 is offline
