painting top of Hardtop white - JeepForum.com
post #1 of 8 Old 07-04-2020, 07:32 PM Thread Starter
Coyotejunki
Coyotejunki's Avatar
My 2015 JKUR has the typical black hardtop. Has anyone painted just the top of it white to keep the heat down? Was thinking white or silver to reflect. Any Ideas on prep or type of paint?
Coyotejunki is online now
post #2 of 8 Old 07-05-2020, 02:21 AM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Haven't heard or seen a lot here; but it's fairly common in the CJ side of things.
A lot more seals on the JK to paint around, but it should be doable.
#1, don't sand it. Thats horrible when they are half sanded smooth.
General consensus is to clean them well , and either spray or roll. (Seriously).
You want a semi gloss at most, not too shiny. Anything with a decent UV protection. Do NOT want use Berliner or raptor or such.
What color is your jeep. I think White would be ok on some, but silver would look terrible on all .
Hoss
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is offline
post #3 of 8 Old 07-05-2020, 06:39 AM Thread Starter
Coyotejunki
I was thinking of painting just the flat part on top, basically no one would see it unless they are really tall. Not the sides. My Jeep is Red.
post #4 of 8 Old 07-05-2020, 06:55 AM
Pillswoj
Pillswoj's Avatar
2014 JK Wrangler
When I had to do fiberglass repairs on my TJ hardtop I cleaned it really well and then gave it a wipe with zylene. After that I rolled it with a high quality exterior acrylic eggshell. I was painting it black again but it should be the same for white. Mine you could not tell it was not the factory paint job.
Jeff
2014 2 dr Rubicon
Pillswoj is offline
post #5 of 8 Old 07-05-2020, 07:18 AM
pismo61
pismo61's Avatar
2015 JK Wrangler
What band of paint,Home Depot type or what?Is there a special type for the fiber glass top?Thanx
2015 Red 2 Door(half) 6sp.
pismo61 is offline
post #6 of 8 Old 07-06-2020, 02:25 PM Thread Starter
Coyotejunki
a painter at work recommended a polyurethane
post #7 of 8 Old 07-06-2020, 02:50 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Do you have access to a thermal temp gun? (Or even a thermometer?)
I'm curious how how the inside temp actually gets vs the sides/ Windows.
My guess is that most heat comes in through sides/ glass...
Hoss
JoonHoss is offline
post #8 of 8 Old 07-06-2020, 06:24 PM Thread Starter
Coyotejunki
I have a infrared at work I'll try to get. I noticed a difference by putting my hand against the top that was un covered and an area under a piece of white cardboard.
