No power in Jeep - JeepForum.com
post #1 of 3 Old 11-03-2019, 05:05 PM Thread Starter
Knowl55
No power in Jeep
My 2011 unlimited Wrangler Sport has no power and obviously won’t start. The battery is fine and less than a year old. I had power and my lights work right before I unhooked the battery to change my starter and ignition switch, but when I hooked everything back up there is no power at all. I have tried to put the old ignition switch and starter in again to see if that would work and that didn’t do anything. I have tried unhooking the battery and zip tying the connectors over night and then hooked the battery up the next day still nothing. Any help??
Knowl55 is offline
post #2 of 3 Old 11-04-2019, 06:54 AM
222Doc
222Doc's Avatar
sounds like ground wire issues. the grounds you need to remove and clean. Not just seeing if tight or "looks" good. same for battery connections. My guess.
222Doc is offline
post #3 of 3 Old 11-04-2019, 10:53 AM
cranbiz
cranbiz's Avatar
Make sure the fusable link on the positive battery cable is good.
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
