No more tire envy--for now, BUT I have some rubbing - JeepForum.com
post #1 of 14 Old 02-02-2013, 10:39 PM Thread Starter
chrisguags
I just installed 35" Duratracs with Level 8 Guardians onto my 2dr JK, only has a 2.5" RC spacer lift on it. Everything clears, driving on the road is fine. But when reversing at full turn (or close to it at least) I have some rub on the air dam. How much should I trim? Can I leave it on and trim it or do I have to take it off?
ALSO, important, the pinch seam. I read up a lot about cutting it. It's not hitting, yet lol, but what do you guys suggest? I'll post a couple pictures.
Sitting on a curb, the pinch seam is quite close (next post also):
chrisguags is offline
post #2 of 14 Old 02-02-2013, 10:42 PM Thread Starter
chrisguags
As you can see, just from sitting on the curb, practically no flex and its very close. What do you think?
post #3 of 14 Old 02-02-2013, 10:46 PM
McDonell
Nice!
McDonell is offline
post #4 of 14 Old 02-02-2013, 11:02 PM
Xodius
First, close only counts in hand grenades and horse shoes.
Second, look great!
Third, I have 35's on MB72's and they are about that close. When I stuff them on the trail I would hop out and look how close they were to the seam but it always appeared that the distance wouldn't change much. You could always trim or hammer it back. Not sure if I will or not just yet. Although I have been jonesing to plasma cut something else on my rig lol.
Xodius is offline
post #5 of 14 Old 02-03-2013, 09:38 AM
Ruby_Tuesday
When in doubt, cut it out......Cut the pinch seams, takes 5 minutes?...
I cut the air dam on the jeep with a razor knife, I cut a stright line took off about 6"
Ruby_Tuesday is offline
post #6 of 14 Old 02-03-2013, 11:23 AM Thread Starter
chrisguags
Yes, takes 5 minutes but I don't have any JB weld/similar antitrust coating and I would need to borrow a friends Sawzall. I want to cut it, but with my current tool situation, it becomes a hassle.
I'm definitely going to cut the air dam with a razor knife right now though and see if it keeps rubbing. I'll just have to keep cutting until I find out haha
post #7 of 14 Old 02-03-2013, 12:21 PM
river2c
2014 JK Wrangler
Pull the air dam off as it's flimsy and will get destroyed off road anyway. The pinch seam should be OK. The tires can't get any closer because they rotate on the axis of the fixed control arms. Can't hurt to trim the sharp corner if you are uncomfortable with the clearance though.
2014 JKU Copperhead
river2c is offline
post #8 of 14 Old 02-03-2013, 02:55 PM
thedirtman
thedirtman's Avatar
You can simply take a hammer and smash that pinch seam flat.
As your axle droops the tire will move closer to the center of the vehicle so checking during stuff really wont tell you anything. The higher the lift you have the more your axle will travel as well unless you are running a nicely set up long arm.
If you learned something new today, you had a good day.
thedirtman is offline
post #9 of 14 Old 02-03-2013, 04:54 PM
brianjw
Also keep in mind that the control arms have rubber bushings that compress. Just because it doesn't run when it's static doesn't mean it will clear when you're trying to dig out of a hole or something.
It just takes a minute with a sawzall to trim the pinch seam. Stuff some epoxy or RTV sealant in there like a lot of us do, and cover it with paint.
You can remove the air dam or trim it. I removed mine initially, then I decided to cut it with a jig saw. I just stuck masking tape as a rough line of where I wanted to cut and went at it.
brianjw is offline
post #10 of 14 Old 02-04-2013, 01:17 PM Thread Starter
chrisguags
I think I'm just going to hammer it flat and cut it off at a later time. I already trimmed the air dam and that was so simple.... Didn't even make a line. I just started cutting down the line already on the air dam. Went well
post #11 of 14 Old 02-05-2013, 01:46 PM
Spike6901
'14 WK2: Armor, Dog Taxi
'17 JKU: Lift, Armor, more...
'97 ZJ: Lift, exhaust, more...
Spike6901 is offline
post #12 of 14 Old 02-05-2013, 01:47 PM
Spike6901
The air dam, although gay, does help to keep your hood from fluttering so bad on a windy day at highway speeeds. So, if you can trim it, you would be better off until you destroy it anyway.
post #13 of 14 Old 02-05-2013, 07:17 PM
GPV
If you wheel your Jeep it will come off.....................
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
post #14 of 14 Old 02-05-2013, 10:18 PM
xflstl
xflstl's Avatar
2010 JK Wrangler
Daystar hood latchs fix that flutter like right now.....
xflstl is offline
2.5 inch lift , 35s , duratrac , guardian , rubbing
