New JK owner - JeepForum.com
post #1 of 6 Old 10-03-2015, 07:17 AM Thread Starter
jeepnoob01
2008 WK
New JK owner
Hey guys, I'm new to the JK side of the jeep world. I just bought a 2008 jeep wrangler unlimited X. this is my second jeep, moving on from my WK after a bad accident, i am looking to start new.
Any advice for beginner mods?
Also plan on lifting and running 35's i understand there is a lot of work with this, any advice on what exactly i have to do to make this dream a reality.
Thanks guys!
jeepnoob01 is offline
post #2 of 6 Old 10-03-2015, 09:54 AM
BRC_1980
Are you going big or just driving on the street? In my opinion, if you are not doing 3+ trails, I would just stick to BB and 35's. Your jeep will still be capable of doing quite a lot. There's at least 5 levels of builds. All depend on budget and what you want to actually do. First level is what I mentioned.
BRC_1980 is offline
post #3 of 6 Old 10-03-2015, 10:02 AM Thread Starter
jeepnoob01
2008 WK
It is primarily going to be on the streets with the occasional trail here or there. I am just looking for something a little bigger and more aggressive.
post #4 of 6 Old 10-03-2015, 10:14 AM
Neo1130
2015 JK Wrangler
Not a lot of work at all. I had 35's on my 2009 Rubi with a 2.5" BB lift. I then added another 1.5" with 4 door springs and called it good. Total of 4 inches of lift and I only really rubbed with the swaybar disconnected on full flex.
Neo1130 is offline
post #5 of 6 Old 10-03-2015, 11:16 AM
222Doc
222Doc's Avatar
Gears is one issue. That will cost as much in not more than the lift.
Building to that task is hardly what most do. In Cal most the trails are from 1-10 and 3.5 is like a flat dirt road. In AZ 3.5 is medium since we rate 1-5. For most drivers at that point it about lockers as well as the rest. better drivers can get through just harder on the jeep at 4. must have lockers. 3.5 lift would be min. as well or ride the belly on rocks.
on a older Jk and even new, issues pop up with 35"s. worn out ball joints, very common. Unite bearings and tres all wear much faster, depending on use Ball joints stock have failed well under 20k with 35"s and rough trails as the diet tend to distroy the stock plactis lined Bj's.
222Doc is offline
post #6 of 6 Old 10-03-2015, 09:48 PM
crazyj23
35's fit easy with the $179 lift from Rough Country
crazyj23 is offline
