New to the Jeep world - JeepForum.com
post #1 of 24 Old 01-29-2016, 02:18 PM Thread Starter
tallica8402
Hello,
I'm currently looking to purchase a Jeep Wrangler. I just have one question really. I don't plan on doing any rock crawling or climbing; or nothing too crazy. I only plan to go off road a little bit and maybe sling some mud around. Is a Wrangler sport, I guess, good enough for that or should I look at a Rubicon? Any advice you guys could input would be greatly appreciated. Thanks!
tallica8402 is offline
post #2 of 24 Old 01-29-2016, 02:36 PM
Neo1130
2015 JK Wrangler
Sport would be perfect for it... You can always modify to your situation and style later on...
Neo1130 is offline
post #3 of 24 Old 01-29-2016, 02:42 PM
pdxkale
2016 JK Wrangler
I had the same quandary a few months ago. I think it really depends on your budget and wants. I liked some features on the Rubi, like the larger tires, rock rails, and D44 rear, but didn't want to swallow the price increase for features I didn't really need, like the lockers and sway bar disconnect. I ended up going with the Willy's Wheeler edition since it gave me a good compromise of the Rubi tires, suspension, rock rails, limited slip rear, at about $5-7K less than a similarly equipped Rubi. I plan on just taking logging trails, trips out on the sand at the coast, and just bombing around the back roads of the PNW with the wife and dogs. If you cannot decide between the Sport and the Rubi, it might be the mid-point you are looking for.
PDXKale - '16 JKU WW
pdxkale is offline
post #4 of 24 Old 01-29-2016, 11:14 PM Thread Starter
tallica8402
Yea, I was looking at some Sahara's too. Thanks for the input guys. Once I actually get a jeep i'll be active on the forums.
post #5 of 24 Old 01-30-2016, 12:52 AM
Prot
Prot's Avatar
2014 JK Wrangler
All JK's except some early production 2007 2 door models have a D44 in the rear. Rubicon also features D44 in the front whereas other models have D30 in the front. Also worth noting is the spline count of rear D44 in a rubicon is higher than other models.
Rubicon also have lockers in both axles, electronic sway bar disconnect, and a lower gear ratio in the transfer case among other things.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #6 of 24 Old 01-30-2016, 09:00 AM
18Fox20
Sport or Sahara would be more than ample for your described needs. To my knowledge all JK models are equipped with a two speed transfer case and BLD. Even the Willy's model would likely be overkill for your needs. Might be better off spending the difference on add-ons and mods that you'll actually use. My 2.
18Fox20 is offline
post #7 of 24 Old 01-30-2016, 01:51 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2020 JK Wrangler
Just keep in mind if you ever DO want to have higher capability later... only the Rubi brings an OEM 4:1 transfer.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #8 of 24 Old 01-30-2016, 02:38 PM
JIMBOX
JIMBOX's Avatar
2018 LJ Wrangler
Just as Mr. Bishop says, and--
Most of the "THINGS" you may wanna add to your jeep--later ---
Are already there if you buy the Rubi, plus your resale value will stay high with the Rubi and on an ordinary model--you'll loose over 50% of any price you may spend onit--
Whatever-
JIMBO
Firecracker Red 2dr RUBICON--2018
Stinger Yellow 2016 RAM/Hemi/8spd auto 4x4
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #9 of 24 Old 01-30-2016, 07:11 PM Thread Starter
tallica8402
I like the Rubicon but I don't think I'll be able to find one within my budget.
post #10 of 24 Old 01-30-2016, 08:36 PM
79cj7amc304auto
Shortly after I bought my Rubi I was kicking myself bcs I thought I made a mistake by buying vs upgrading. But after almost three years I am SO glad I went Rubi. I can't lie... I wouldn't have as capable a jeep as I do right now. I'm lazy like that. My interests changed quickly and it's nice to upgrade the Rubi as a starting platform. Just the gears, lockers, transfer case and d44 front would eat up a big chunk of your savings. If ur not planning to go full out ridiculous like d60s, 37"+ tires, new drivetrain and such... Then a rubicon is nicely built and probably a good decision worth considering. Resale value alone will save ur *** big time if you decide jeeping is just not for you later on down the road. You can sell in a few years for 7-9k more than a standard sport. Spend now and save later is my recommendation.
79cj7amc304auto is offline
post #11 of 24 Old 01-31-2016, 06:20 PM
18Fox20
It is undeniable that a Rubicon is the better choice if you are going to do hardcore off-roading, but the OP made it clear that he was not. I've come to realize that for snowy roads, trails, and pastures that I did not need to spend $ on tempting upgrades to my former CJ, TJ, or LJ. What I did find most useful was a quality safari top, bedliner, and tires. Got my $ worth out of those items regularly. If I was rich I'd get a Rubicon AND all the aforementioned items, but I had to choose. Again, just my take. Spend your $ how you want.
18Fox20 is offline
post #12 of 24 Old 01-31-2016, 07:28 PM
JIMBOX
JIMBOX's Avatar
2018 LJ Wrangler
Nope the Rubi is the better choice if you wanna start with the best/warranty'd/outfitted jeep/w NO DOWN TIME, or additional CASH, You can start with that as your base and go from there-the only thing I've discarded from my Rubi--in 7-1/2 tears, is the 4.10 gears and they aren't even Rubi !
It's still the best financial jeep purchase, whether you use the attributes or not--when you sellit--you won't lose much money, compared to one you "MODIFY" !
Wharever
JIMBO
JIMBOX is offline
post #13 of 24 Old 02-01-2016, 07:58 AM
79cj7amc304auto
The OP made it clear that he's new to the jeep world so his intended uses can change very quickly. I just wouldn't wanna be stuck with a 34k jeep that can't do what I want it to do without major mods (or do it as easy) when I could have bought a jk for a few bucks more. Seriously if a few thousand bucks is a major concern, then maybe someone should consider a used jeep or something different altogether.
post #14 of 24 Old 02-01-2016, 07:47 PM
18Fox20
Fair enough. BLD and LSD have been sufficient over the last 8 years for my purposes. I get that aftermarket mods don't yield much return on resale, but that assumes that you even need them. I'm not going to tell the OP what his needs are or if they will change. Mine did not.
Rubicon is an incredible machine, and I would have never even had an opportunity to exploit it. That $5k extra would have just sat unused in lockers, suspension components, and a front D44. More than 30k is my personal breakpoint, and buying used Wranglers just scares me unless I know the previous owner. Both arguments make sense, but I'd rather have cash in hand/invested. Rubicon is not for everyone.
18Fox20 is offline
post #15 of 24 Old 02-02-2016, 04:28 PM
jwmbishop
jwmbishop's Avatar
2020 JK Wrangler
I'm with you on the cash in hand thing - I just pointed out the Rubi transfer cuz that's where I hear a lot of guys bemoan their decision later (they had no intention of climbing the mountain until the mountain appeared in front of them) - but also the guy who wants to go Atlas 5:1 later (after struggling at 2:1 watching the 4:1 do so well) is happy he didn't buy a Rubi!
