New Aluminum Door Handle JK - Opinions? - JeepForum.com
 1Likes
  • 1 Post By cranbiz
post #1 of 10 Old 03-10-2019, 08:10 PM Thread Starter
dvanzant
dvanzant's Avatar
I was challenged to make a set of aluminum door handles for the JK and this is what I came up with. Keep in mind this is the first try. I need to clean up the cnc program a bit to improve the finish.
What are your thoughts on the overall look? Any thoughts for improvements?
dvanzant is offline
post #2 of 10 Old 03-11-2019, 07:54 AM
Randglerjk
Randglerjk's Avatar
Looks good. Id like to see how it looks like on a door.
Sent from my iPhone using Tapatalk
Randglerjk is offline
post #3 of 10 Old 03-12-2019, 01:26 PM Thread Starter
dvanzant
dvanzant's Avatar
Thanks! I plan on doing a check fit this week and will machine a set once verified. I'll post another pic once it's installed.
dvanzant is offline
post #4 of 10 Old 03-12-2019, 01:42 PM
propped1
propped1's Avatar
So this uses the underlying spring and mechanism, but is a complete handle replacement? Id be interested depending on price. Rampage makes something similar. I dont like the design, but would like metal handles. Rampage does aluminum or stainless. I wouldnt put chrome, polished or raw aluminum on my rig. They need to be black - flat preferrably - or need to be able to make them black at a powder coater.
4" lift, PR 44, PR 60, 5.13, 37 Toyo MT, ATX Slabs, Skids, PSC Big Bore, 2Way
propped1 is offline
post #5 of 10 Old 03-12-2019, 01:52 PM Thread Starter
dvanzant
dvanzant's Avatar
Thanks for the input!
Correct, it will install in place of the existing handle without any mods.
I have the same opinion, there are some existing aluminum handles out there but I'm not in love with any of them. I can understand their look though as the challenge is to come up with something that can be machined efficiently. The more "organic" the shape, the longer it takes to machine... more time = more cost.
Same opinion on the finish as well. I prefer black (or darker color) and maybe a machined accent or exposed aluminum. The handle would most likely need to be anodized as the thickness of a powder coat might hurt the push button function.
dvanzant is offline
post #6 of 10 Old 03-12-2019, 02:01 PM
Randglerjk
Randglerjk's Avatar
Why dont you look at the tailgate hinges of the JL and use that style for the handle. If you can make the handles appear seamless like those hinges youll have a best seller.
post #7 of 10 Old 03-13-2019, 02:01 PM Thread Starter
dvanzant
dvanzant's Avatar
Thanks for the input, much appreciated. Could you clarify a bit as to what you would change about the one I did and what you really like about the JL hinges? You can be critical about mine, I don't mind.
Here's why I ask... relating to the hinge, I could create a simple profiled block with a few holes in it and it would only take a few minutes to machine and, unfortunately, it would look like a turd. I could also create something that has great shape and style but might not be "geometric" and it would take hours to machine. I'm trying to find the balance for something that looks good but is cost/time effective.
dvanzant is offline
post #8 of 10 Old 03-13-2019, 02:35 PM
Randglerjk
Randglerjk's Avatar
That hinge has a classic toolbox style look to it and with it being painted it goes well with the car. That look is classic.
This handle is from a toolbox. How can this be redesigned to be a wranglers handle? This is what i would like on my jeep. Metal on metal - which is what what i like about your handle (the fact that its metal). Oh and will you make a plastic base to protect the paint?
post #9 of 10 Old 03-13-2019, 04:45 PM
cranbiz
cranbiz's Avatar
Unlike some, I really like your design. It looks sleek and modern to some degree.
I could see those on mine.
dvanzant likes this.
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #10 of 10 Old 03-15-2019, 01:28 PM Thread Starter
dvanzant
dvanzant's Avatar
Ok, I know what you mean now. The appealing part of that tailgate hinge is what makes it hard to machine. it much faster to make something that has straight or angled walls. The smooth flowing surfaces require a much longer machine time thus increasing the cost.
And yes, there will be something that protects the paint. It will probably be simple die cut rubber pieces.
dvanzant is offline
WK Aluminum Radiator Patrick181 WK Grand Cherokee & XK Commander Forum 10 03-02-2019 12:02 PM
Looking for advice on working with 6061 Aluminum T-Jay Fabrication Shop 2 07-11-2018 09:04 PM
Artec Industries JL Bellypan in Steel & Aluminum ARTEC Vendor Display 0 04-24-2018 11:34 AM
Exhaust manifold shield? Aluminum on header ok? mystangt XJ Cherokee Technical Forum 3 02-27-2018 11:56 AM
Aluminum rear bumper + bolt on trailer hitch SkylinesSuck TJ Wrangler Technical Forum 16 02-15-2018 01:59 PM
