Need Some Advice - JeepForum.com
post #1 of 5 Old 03-27-2018, 05:59 PM Thread Starter
HencetheShock
Need Some Advice
I have a 2012 Jeep Wrangler 4wd Sport with stock wheels and tires (225/75/16). I wanted to upgrade my current tires and wheels on the Wrangler and I need some advice. I want to put a 285/75/17 tire on without lifting the Jeep. Iíve heard different things regarding backspacing/offset numbers. So the current wheel Iím looking at is a 17x9 with -12 mm offset with the aforementioned tire. Can I make this work without a lift? What mods if any will I need to make (stubby bumper/leveling kit?)? If -12 mm is too little what do you recommend? Iíd like to keep the 285/75/17 tire but will go to a 285/70/17. I know this is wordy, but I donít want to invest a couple thousand dollars into tires and rims and get the incorrect specs. Thanks for any and all help and advice.
HencetheShock is offline
post #2 of 5 Old 03-27-2018, 08:03 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Stick with the 285/70 if you don't want to lift it .
Throw a cheap easy 2" budget boost or leveling kit on, and you can run the 285/75's
As for the new rims, play around here all you want https://tiresize.com/calculator/
Hoss
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is offline
post #3 of 5 Old 03-28-2018, 10:35 AM
cranbiz
cranbiz's Avatar
Use the tire size calculator that Hoss gave you and then go here for fitment questions.
https://www.jeepforum.com/forum/f96/j...reads-1074059/
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #4 of 5 Old 03-29-2018, 07:53 AM
FireGuy1996
FireGuy1996's Avatar
I currently have 285\75\R16 Duratracs. The wheels are procomp series 7069, 16x8 with 4.75" backspacing. A 17" setup shouldn't be too much larger.
No rub while turning at all. I had very minor rub on the factory fenders at full suspension flex but I solved that with flat fenders. No lift at all, however I do plan on doing one later on.
I used the two tools linked above when picking out my combo, super useful!
FireGuy1996 is offline
post #5 of 5 Old 04-04-2018, 12:47 PM
svigilrrnm
Originally Posted by HencetheShock View Post
I have a 2012 Jeep Wrangler 4wd Sport with stock wheels and tires (225/75/16). I wanted to upgrade my current tires and wheels on the Wrangler and I need some advice. I want to put a 285/75/17 tire on without lifting the Jeep. I’ve heard different things regarding backspacing/offset numbers. So the current wheel I’m looking at is a 17x9 with -12 mm offset with the aforementioned tire. Can I make this work without a lift? What mods if any will I need to make (stubby bumper/leveling kit?)? If -12 mm is too little what do you recommend? I’d like to keep the 285/75/17 tire but will go to a 285/70/17. I know this is wordy, but I don’t want to invest a couple thousand dollars into tires and rims and get the incorrect specs. Thanks for any and all help and advice.
My 2012 Jk sport with 265/75/16 with 1.75 spacer lift
svigilrrnm is offline
jeep , jk , offset , tires , wheels
