Need a good replacement steering box - JeepForum.com
post #1 of 4 Old 03-11-2019, 05:40 AM Thread Starter
John Strenk
John Strenk's Avatar
1976 CJ5
My sons steering box broke this morning on the way to work. First day on the new job also!
Anyway he’s looking for something he can throw on there for a few months before he’s gone for a year or so. He doesn’t have much money at the moment.
It’s a 2008 2dr. on 37” tires. Does this happen a lot with oversized tires or just a freak failure?
Any suggestions?
Don’t want this to happen again. I figure he was lucky today.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #2 of 4 Old 03-11-2019, 07:27 AM
propped1
propped1's Avatar
I dont know where shalersville OH is, but Im in NKY. I have a stock JK box sitting in my parts bin I'd sell. I went PSC big bore a year and a half ago. Mine was working fine prior to swap. I just wanted hydro for wheeling. It had 90K miles, has pitman arm attached, and I even have a stock draglink. You might be able to find one closer to home.
As far as does this happen a lot? Yes it does. If you are running big tires, you want hydro assist. Can tap stock box, buy one ready for it, or get the full aftermarket from PSC. The flaw in the JK box is the length of the sector shaft. With big tires, it either breaks exactly like what yours is, or the long sector shaft flexes in the housing and it'll start leaking and youll burn up a gear or pump. More commonly its the break.
The PSC big bore makes the shaft larger. 35mm stock. 45mm in the PSC. You dont NEED the bigger sector if you add hydro. Redneck ram is the cheapest way to do that. Can send yours in if its not broken and they send you one. PSC BB 900 bucks... 1300 ready for hydro. New JK boxes are 550 from Crown 700 from PSC 720 from Mopar. reman at autozone is 230 plus 65 for a pitman arm... Long term solution? Probably not, but you said short term. AZ says limited lifetime warranty... With a steering gear, I wouldnt want to do that job again personally even if the parts are covered.
4" lift, PR 44, PR 60, 5.13, 37 Toyo MT, ATX Slabs, Skids, PSC Big Bore, 2Way
propped1 is offline
post #3 of 4 Old 03-12-2019, 06:38 AM
rcoe
With 37's I would either go with the PSC HD unit or at the very minimum get a sector shaft brace kit. Synergy makes a nice kit that also beefs up the front track bar mount.
rcoe is offline
post #4 of 4 Old 03-12-2019, 08:04 AM
waterdowg
waterdowg's Avatar
John,
Check out www.car-parts.com It will give you an inventory of your local salvage yards. I looked in your area and they ranged from $125-$200 depending on mileage.
waterdowg is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3864 10-19-2019 10:58 PM
Steering Box Play after Rebuild - video StanF YJ Wrangler Technical Forum 1 12-05-2018 04:28 PM
Steering box inspection sAe23 XJ Cherokee Technical Forum 4 11-04-2018 01:24 PM
Replacement steering shaft jay5.9l Jeep CJ Forum 32 07-20-2018 02:36 AM
Power Steering Gear Box Help bohmerjr Jeep CJ Forum 6 05-05-2018 09:29 PM
