MYGIG Database Thread - Page 12 - JeepForum.com
post #166 of 212 Old 02-20-2015, 12:10 PM
mat8828
1983 CJ7
It would seem so, there is a recall on the ignition switches that they don't have parts for. But apparently there is a fault in the power to them/through them that might have been causing this. It would also screw with the warning lights and other things. Quick fix, that seems to have fixed my radio issues as well.
mat8828 is offline
post #167 of 212 Old 02-23-2015, 07:36 AM
xsdbs
press and release the Uconnect phone button and say "English", then Uconnect will ask if you want to select English.
Originally Posted by MrSundays View Post
Just bought a 2013 JKR and it came with the RES I believe with the external uconnect module. Somehow the uconnect is in Spanish! How can I do a reset on the module? Does the battery just need to be disco'd? Thanks yall!
Sent from my pocket brick
xsdbs is offline
post #168 of 212 Old 02-25-2015, 11:10 AM
jchappy
2011 JK Wrangler
I have an 730N RHR with firmware 1.911 and gracenotes 3265, can I upgrade to V. 2.600 and GN 6168 with out issue?
whats the changelog between the two?
MY NEW JEEP- 2011 JEEP JKUR, Body Armor front bumper, Warn XD9000I winch, Synthetic winch line,XRC Rear Bumper W/Tire carrier, OBA W/1Gal Tank, Terafex 2.5in spring lift, Bilstein 5100 shocks,GY 315/70R17 Duratracs, 4.88 G2 gears, Cobra 75 CB
MY OLD JEEP-1999 Wrangler Sport 4.0L, 4" Pro Comp Lift, 33" BFG's, 8K winch, SYE, Viking soft top, onboard CO2 and all the recovery straps and equipment
jchappy is offline
post #169 of 212 Old 03-03-2015, 12:32 PM
jtcorbin
I have searched as best I could without finding an answer so hopefully someone here can help me out. I just purchased a MyGig REN from a seller on ebay with the description that it was a high speed unit. After install, it only half the time will flash the Jeep logo at start up and almost immediately starts playing audio from SiriusXM radio. The screen is completely black (off?) and none of the buttons are functional. I took my ride to the local dealer and they said that only a RER unit will work in my Jeep. They told me that they were getting a message that said "lost connection" when they looked into things. From what I can tell from various websites a REN unit should compatible with my Jeep. I have attached two pictures showing the factory stickers in the hopes that someone who knows a great deal about the radios can help (the part # is P05064759AC). Did I end up getting an incorrect unit? I have a '07 Sahara two door with the infinity sound system/sub and SiriusXM antenna and no steering wheel controls. It came with the RES unit originally.
jtcorbin is offline
post #170 of 212 Old 03-04-2015, 11:21 AM
MileHighBuckeye
MileHighBuckeye's Avatar
2014 JK Wrangler
Hey guys and gals! I've recently started experiencing issues with the 430N in my 2014 JKUR. When you're using the navigation, the system will sporadically either crash to a black "Guidance by Garmin" splash screen, and will stay there for some amount of time before the maps come back OR it will randomly go to a "Test Mode" screen. Also, the USB port in the arm rest no longer receives power when starting the Jeep. It will randomly get power throughout the course of a trip (anywhere from 5 to 30 minutes after starting the vehicle), rendering me unable to connect my phone for charging or media streaming. Has anyone else experienced issues similar to this? I've looked around the forum, but haven't been able to find any posts regarding this issue. Thanks in advance for the responses!
14 Rubicon Unlimited
MetalCloak 3.5 6Pak Edition
37" STT Pros, 4.88s
MileHighBuckeye is offline
post #171 of 212 Old 03-06-2015, 06:22 AM
xsdbs
I have read about others having similar issues and it ended up being a HW issue and the radio(s) were replaced under warranty.
xsdbs is offline
post #172 of 212 Old 03-16-2015, 04:41 PM
revans3437
2011 TJ Wrangler
Ok, I accidentally disabled the touch portions of the radio through the engineering portal. So, how to get back to the engineering portal to re enable the touch part of the radio. I tried pulling the IOD fuse to reset the radio, and it did reset the time and such, but it didn't reset the screen back so i could even go through the calibration, which I have done before.
Can anyone help, as to what my next step is?
revans3437 is offline
post #173 of 212 Old 05-01-2015, 11:00 AM
myrddin
2009 JK Wrangler
Good stuff in this thread... I wish all the links worked? Anyone know of a repository? Trying to learn about the My Gig in the 2009 Unlimited Rubicon I have.
2009 JKU with a Rugged Ridge Short Winch Bumper and a WARN ZEON 10-S winch
myrddin is offline
post #174 of 212 Old 05-04-2015, 03:18 PM
revans3437
2011 TJ Wrangler
So, I hope someone has the answer to a disabling the touch portions of the menu. While calibrating and in the engineering mode, I accidently disabled it, thinking I could just re enable it. Well, touch won't respond at all. I made a few calls to Chrysler, who had no idea. I finally got through to the company that originally used to service them solely for Chrysler (they don't anymore). and they told me I would have to replace the whole touch screen with a new, which they said would reset it, but that's $250, which isn't worth it versus just replacing (is what Chrysler wants me to do). I tried disconnecting the fuse to the radio, but all that did was reset the presets, time, preferences, etc. I read where you can downgrade the firmware, which automatically brings up the calibration menu, but no one including Chyrsler has the 9.1 version firmware. So..I am hoping someone has a work around, and if not, at least the info I have found so far is out there for someone to read. BTW, i have a 430 REN non Navigation radio.
post #175 of 212 Old 05-16-2015, 12:19 PM
terpsmandan
You can add the microphone and turn on the Bluetooth. No A2DP however. Because of the HDD, I am not going to get the iPod cable. Not sure if it will work with the 30 pin to lightning adapter.
terpsmandan is offline
post #176 of 212 Old 06-20-2015, 09:52 AM
jimbo92
2011 JK Wrangler
Just ordered my 2015 Rubicon Hard Rock without the Nav. Figured I would go aftermarket and got to playing with my buddies 430N with garmin and loved it. Went to add it to my order and too late, because it is a sold order they already put it in d status. If I order a late model 430N online is it plug and play?
I have sat radio, and connectivity/uconnect optioned out on the jeep. From what im reading I shouldnt have to add anything for the gps to work and all the voice command stuff should work as intended right?
jimbo92 is offline
post #177 of 212 Old 06-22-2015, 04:46 AM
xsdbs
Yes, this would be a PnP installation. The only small issue is to try to make sure you get the security code for the radio. If not, then you'll need to take the vehicle and a bill of sale to the dealership. They'll be able to place a call to get the security code and at the same time, they'll enter your VIN# into the computer system as the new owner of that radio.
xsdbs is offline
post #178 of 212 Old 07-17-2015, 02:30 AM
jespuna
Mygig and Jeep KK (Cherokee / liberty 2008)
Help! Buy online MyGIG rb2 to install one in my jeep kk (Cherokee or Liberty 2008). When connecting-the unbootable. Why? thank you very much
Ayuda! Compre por internet un mygig rb2 para instalar en mi jeep kk (cherokee o liberty 2008). Al conectar-lo no arranca. Porque? Muchas gracias
jespuna is offline
post #179 of 212 Old 07-17-2015, 02:44 AM
jespuna
Ayuda! Compre por internet un mygig rb2 para instalar en mi jeep kk (cherokee o liberty 2008). Al conectar-lo no arranca. Porque? Muchas gracias!
jespuna is offline
post #180 of 212 Old 07-20-2015, 07:33 AM
xsdbs
can you explain this a bit better? I'm not really getting it.
1) What year and model vehicle do you have?
2) What year and model vehicle did the radio come out of?
3) What do mean by "unbootable"?
xsdbs is offline
database , information , JK Wrangler , mygig , wrangler
Got my Mygig uconnect working highoctane JK Wrangler Technical Forum 11 07-14-2009 03:12 PM
Iphone 3.0 and uconnect Cavi JK Wrangler Technical Forum 2 06-17-2009 08:44 PM
Uconnect, Iphone G3, Worked now dosen't, No Dealer Help! consultJK JK Wrangler Technical Forum 13 06-16-2009 12:28 PM
uConnect on '08 JK w/MyGIG? OffRoadRyder JK Wrangler Technical Forum 5 10-20-2008 06:05 AM
MyGig Uconnect set up Scootr JK Wrangler Technical Forum 0 05-05-2007 08:46 AM
