Looking for skid plate advice - JeepForum.com
post #1 of 14 Old 02-09-2020, 02:56 PM Thread Starter
SC20K
SC20K's Avatar
Looking for advice. I bought the Rubicon express oil pan skid for my 07 jkur. There's an access hole for the drain plug but I use an EZ drain valve which I love and won't get rid of. The valve doesn't quite clear the hole. Simple solution is to cut the hole bigger but I don't want to make a hack job out of it. I need to find someone with a cutting torch to make a nice clean cut don't I?
I also got the Rubicon Express manual transmission skid. The rear oem star bolts in the transmission are what this piece uses to mount in place. I can get to then and turn them but can't get them out. Looks like the transmission frame cross member needs to be removed to get these bolts out and back in. Do I need to support the transmission with a transmission jack or can I just remove the cross member without doing that? I don't want the transmission falling on my head lol.
SC20K is offline
post #2 of 14 Old 02-09-2020, 03:47 PM
turbinemech70
turbinemech70's Avatar
2017 JK Wrangler
You could use a jig saw to cut the hole out if you choose. Torch may weaken the skid plate IMO
You need to support the transmission with a jack, doesn’t need to be a trans jack.
2017 Jeep Wrangler JKU
3.6L 6-speed manual
4.56 gears
Yukon ZIP air lockers
turbinemech70 is offline
post #3 of 14 Old 02-09-2020, 03:48 PM
222Doc
222Doc's Avatar
you need to support it. You should be able to add a bit of hose to the fumoto valve, that way you just drop the hose in the container no mess no fuse no need to cut.
222Doc is offline
post #4 of 14 Old 02-09-2020, 03:48 PM Thread Starter
SC20K
SC20K's Avatar
Thanks for the reply. Will a jigsaw cut through the thick hard steel plate?
SC20K is offline
post #5 of 14 Old 02-09-2020, 03:50 PM
222Doc
222Doc's Avatar
its not harden steel but may be 1/4 thick. again just use a hose.... I have cut 1/4 with a jigsaw. You must drip oil on as you go or you will use every blade harbor freight has......i use 90 weight for those PITA jobs.....
222Doc is offline
post #6 of 14 Old 02-09-2020, 04:40 PM Thread Starter
SC20K
SC20K's Avatar
Hmmmm, yeah definitely will need oil. I guess its worth a shot. Just need to but a jigsaw.
SC20K is offline
post #7 of 14 Old 02-09-2020, 04:52 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
A good hole saw and a strong drill.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #8 of 14 Old 02-09-2020, 05:28 PM
222Doc
222Doc's Avatar
just add a hose to the barb. coil it up in the shield and put the cover on it most those skids have a removable cover plate. so simple.............. if it dont have a cover for that hole just zip tie it off.
222Doc is offline
post #9 of 14 Old 02-09-2020, 06:06 PM Thread Starter
SC20K
SC20K's Avatar
I thought hole saw bits were just for wood. If they make ones for steel, this is a good option.
SC20K is offline
post #10 of 14 Old 02-09-2020, 06:07 PM Thread Starter
SC20K
SC20K's Avatar
I get what you're saying but the skid plate actually gets caught on the drain valve and can't be installed without the hole being enlarged.
SC20K is offline
post #11 of 14 Old 02-09-2020, 06:14 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
You can get carbide tipped ones specifically for metal from any larger hardware store.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #12 of 14 Old 02-09-2020, 07:25 PM Thread Starter
SC20K
SC20K's Avatar
Perfect thanks. That is definitely the way to go. I'll try it anyways.
SC20K is offline
post #13 of 14 Old 02-14-2020, 06:44 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Check out Fumato valve. It comes in different drain nipple configuration, so you could make it work.
2009 JK Rubicon, 2004 TJ now gone
2019 Mustang GT 6 Spd DD
2017 Porsche 718 Cayman
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine, LCA & Evap Skid; Rock Hard Gas Tank Skid; Warn Stainless Diff Skids, Pull-Pal, Uniden 520XL CB, Aeroforce Interceptor, Valentine 1
Ouray - TJ-8/07
Moab - TJ: 4/06, 5/08, JK: 4/09, 5/11, 4/13, 5/16, 4/17, 5/18
Rubicon - TJ-9/08
Thunderstrike is offline
post #14 of 14 Old 02-16-2020, 12:15 PM Thread Starter
SC20K
SC20K's Avatar
Installed my Rubicon express oil pan skid. I refused to lose my EZ oil drain plug because it makes oil changes so quick and easy so I had to lengthen the oil plug hole with a step bit and grinder. It doesn't hang down, it sticks out on the back side so should be ok. If it gets hit, I'll deal with it then.
IMG_20200216_111325_148_1581880485710.jpg   IMG_20200216_111325_150_1581880493026.jpg   IMG_20200216_111325_149_1581880499703.jpg
SC20K is offline
