Long arms for Coilovers? - JeepForum.com
post #1 of 6 Old 08-07-2020, 04:36 AM Thread Starter
Koakang714
I dont know if this is where I would post this but here it goes.
I am pretty set on getting some coilovers and getting suspension lift kit that is two and half lift
I have been told when having coilovers long arms are preferred for maximum flex. Is it needed? Also when I look for two and half inch lift suspension kits they do not
have long arms.
Is this something I need to buy separately as a whole? So I could have long arms?
Can someone point me to a dependable two and a half inch suspension kit ? i have looked at metalcloak, teraflex . I am looking for something that would support coilovers?
Thank you I am pretty new to this
Koakang714 is offline
post #2 of 6 Old 08-07-2020, 08:55 AM
222Doc
222Doc's Avatar
coil over to well is a going to be 15k, just in parts. 2.5 lift and coil over is ridiculous. You want a good coil over lift??? Money not an issue. Look at Genright
Most long arm kits have horrible geometry. Do to the way a JK is. They as well tend to have less belly clearance as the arms get hung up. Lifts that are well designed and long will be triangulated 4 link. BUT to even consider this type lift you will not want to use d30/d44 or even d44/d44< again its just ridiculous. BUt now to go full float axles in 1 to you just spent another 15k. Non of this bolt on and labor will about double cost.
I would bet the Metal cloak game changer will serve you better. want a lot of flex then go with their six packs and a game changer. still in the 4+k range,,,,,,
222Doc is offline
post #3 of 6 Old 08-10-2020, 11:56 AM Thread Starter
Koakang714
INFO
Can't I just get these two things?
metalcloak.com/jk-wrangler-four-link-long-arm-compound-suspensions-4-5in.html#reviewshttps://metalcloak.com/jk-wrangler-four-link-long-arm-compound-suspensions-4-5in.html#reviews
accutuneoffroad.com/product/complete-weld-jeep-jk-coilover-kit
and I would be good to go?
post #4 of 6 Old 08-10-2020, 01:12 PM
222Doc
222Doc's Avatar
You can do anything with enough money.
My 2 door JKR on 4.5 ish depends on the load in it.
flexs rather well , rides well. Franken lift of parts. I pick the ones i feel will suit me best. joints to me its Johnny Joints. no matter who makes the arms.
222Doc is offline
post #5 of 6 Old 08-14-2020, 05:21 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
I'm pretty sure Evolution offroad makes a long arm coil over kit in the 2.5" range. It's pretty expensive, but it has a pretty good reputation.
Necromancer_tat is offline
post #6 of 6 Old 08-14-2020, 05:23 PM
Necromancer_tat
Sorry, it's a 3" not 2.5"
Here's a link: https://offroadevolution.com/collect...n-black-jk-jku
