Lockers not engaging - JeepForum.com
post #1 of 5 Old 06-28-2010, 03:24 PM Thread Starter
JK_Jeep
JK_Jeep's Avatar
I have a 2007 Rubicon and my lockers will not lock.
Stock rims and tires, no lift.
Lights blink I am under 18 mph, in 4 low.
I turn the wheel back and forth to help align, no luck.
Any thoughts?
If I take the covers off, can I just spray the diffs with carb cleaner or brake cleaner and try to engage them?
IT'S A JEEP THING!
Originally Posted by sierraexplorer
Thanks, if it is that good than I'm sure that they can't sell it in California. Everything else is illegal in this state except the illegalsl
JK_Jeep is offline
post #2 of 5 Old 06-28-2010, 05:58 PM
Warlord2
you can try that, some people have reported that some gear oils disagree with the locker and dont function well. Im using royal purple at the moment and mine will function 99% of the time within a foot of me activating them. Use brake cleaner, it leaves less residue. Might be a good time to change fluids also. Are you just looking at the lights or have you tried to feel if the lockers are working?
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #3 of 5 Old 06-29-2010, 10:56 AM
ChicagoGuy
Team XBOX
ChicagoGuy's Avatar
FWIW, when I did the gear change, there is a small tab that got broken off that was essentially the sensor for the computer to know the e-lockers had engaged. Created the same symptoms - lights would just blink and never go solid.
Turned out the lockers were working despite this, just not showing up on the dash. Check to see if the axle is still locking. Might just be a bad sensor.
- Bill (formerly VetteDriver)
ChicagoGuy is offline
post #4 of 5 Old 06-29-2010, 11:19 AM Thread Starter
JK_Jeep
JK_Jeep's Avatar
Where do you get your Rubicon worked on in Chicago????? I work in Alsip
IT'S A JEEP THING!
JK_Jeep is offline
post #5 of 5 Old 06-30-2010, 12:08 PM
ChicagoGuy
Team XBOX
ChicagoGuy's Avatar
Sorry, I did it out here in the PacNW. I grew up in Chi town - South Side boy - but live near Seattle now.
For those in Seattle, ECT did the work.
Front Lockers engaging EddieB606 TJ Wrangler Technical Forum 15 04-14-2010 03:22 AM
Lockers not engaging 95North TJ Wrangler Technical Forum 4 02-23-2008 11:16 AM
Rubi lockers not engaging ?? Mr. Coz TJ Wrangler Technical Forum 8 02-06-2007 08:06 PM
Engaging Lockers GeoBigJon TJ Wrangler Technical Forum 17 06-27-2006 04:36 PM
What is the Rubicon mod for engaging lockers in 4H jalbs TJ Wrangler Technical Forum 5 12-04-2005 01:58 PM
