Larger tires, unsrung weight, bouncy suspension - JeepForum.com
 1Likes
  • 1 Post By cranbiz
post #1 of 3 Old 11-26-2019, 09:04 PM Thread Starter
JamesC
Hey all,
2017 jk sport S.
Took off the stock (255??? /75r17) wheels.
Added Rubi rims (they look nicer than the five-spokes).
Increased tire size to 285/70r17 Duratrak with lots of lumpy tread (i.e. more mass).
It's only been about a week so maybe I'm still a little nervous about the change, but on the interstate about 70-ish i hit a really decrepit piece of pavement, really bumpy.
Seems to me that the jeep was waaaaayyyy more jumpy and vibrate-y and jiggly than stock. It was quite alarming, actually, and I can imagine a worse bump at a faster speed might lead to lane excursion or a broken part down below...
Is it because of the increase in unsprung weight due to the new tires???
If so, what is a good solution?
I do not think it is that "wobble", but i don't know - might i get the death wobble just from adding larger tires?
Btw, everything else is still stock. I have not yet added spacers (will need to tho, as hard turns cause rubbing on the sway bar), and have not yet added a leveling kit or poor man's 1.5"-2" lift.
JamesC is offline
post #2 of 3 Old 11-27-2019, 01:31 PM
cranbiz
cranbiz's Avatar
Check your air pressure. Generally tire shops over inflate tires. You probably need to be in the 30-32 PSI range and I'll bet you are close to 40 PSI.
Over inflated tires will cause the condition you described.
JTPhoto likes this.
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #3 of 3 Old 11-27-2019, 02:54 PM
JTPhoto
JTPhoto's Avatar
Ditto ^^^^^
Sent from my iPhone using Tapatalk
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is online now
tires , tires rubbing
