JK Trans drain? - JeepForum.com
post #1 of 9 Old 08-04-2010, 11:50 AM Thread Starter
j_bydesign
j_bydesign's Avatar
JK Trans drain?
What were they thinking when they ran the exhuast cross over directly under the drain plug for the tranny? and why can't we use the same plug for the drain and the fill... not a 14 mm and a 17 mm....
NO COMMON SENTS!
'04 TJ(wheeler) '65 CJ5(sold :( )...'05 LJ(Scrambler conversion, SOLD!) 89' Int. Harvester Toter (SOLD)! '80 CJ7 Resto Mod(sold) 1985 CJ7 Renegade (in process/million pieces) 2000Kenworth Hauler
j_bydesign is offline
post #2 of 9 Old 08-04-2010, 12:29 PM
YJScoot
YJScoot's Avatar
I think it's so that you'll pay them to do labor for you.
Originally Posted by gimme mud!
when tj and jk owners say that jeeps are supposed to have round headlights you can proudly tell them nope there supposed to have leaf springs.
YJScoot is offline
post #3 of 9 Old 08-04-2010, 01:40 PM
nyrangersfan19
nyrangersfan19's Avatar
NO COMMON SENTS!
nyrangersfan19 is offline
post #4 of 9 Old 08-04-2010, 03:14 PM
Ajaxxx
2010 JK Wrangler
I can answer both of those questions:
The exhaust runs under the drain plug because everyone's garage/shop needs to have the wonderful aroma of burning transmission oil.
In seriousness, as an engineer, I support the 14mm/17mm fill/drain strategy. When you are designing equipment for serviceability, having two sizes for fill/drain decreases the chance of error by users. If the service manual tells a person to 'remove drain plug using 17mm wrench, and then remove fill plug using 17mm wrench, there is a larger chance of the user removing the wrong plug. When I worked at a high clearance ag. sprayer manufacturer, the fresh water tank and the spray tank had multiple sized connections intentionally. It would have been easy to use the same connections, but would have added to user confusion.
It's the same strategy as making electrical plugs that can't be inserted 180° from required orientation, or to keep a farmer from connecting hydraulic hoses to the wrong quick connects.
Of course, I may be totally wrong, and it may be a stupid legacy design quirk like cigar lighters in cars (talk about an obsolete and ancient design). It may be that way because 'its been done that way for a long long time'.
IowaAndy
IowaAndy
2010 JK Unlimited Deep Ocean Blue, Auto, Cruise, Softtop, Half-doors, A/C
Ajaxxx is offline
post #5 of 9 Old 08-04-2010, 06:38 PM
bubba2u
2009 JK Wrangler
i tacked a 17mm bolt to a piece of flat stock to get to that drain plug
bubba2u is offline
post #6 of 9 Old 08-06-2010, 03:00 PM Thread Starter
j_bydesign
j_bydesign's Avatar
Ajaxxx while it almost makes sence... as an industrial designer... I am not going to buy it! The fact that chrysler has a tool made for that one job goes to show that somebody screwed up... and the tool was not immediately avalible... KISS is always best but I apriciate your effort to explain it...
bubba2 did pretty much the same thing.
post #7 of 9 Old 03-25-2012, 11:57 AM
GS340
I made my own tool to remove the plug. If you want one I can make another.
GS340 is offline
post #8 of 9 Old 03-25-2012, 12:09 PM
foolsonparade
foolsonparade's Avatar
I'm sure he's figured out what he's going to do by now
foolsonparade is offline
post #9 of 9 Old 03-25-2012, 12:23 PM
GS340
Oh damn. 2010 post. Yeah never know maybe he's stuck under there.
GS340 is offline
drain plug , JK Wrangler , transmission , wrangler
Trans Drain Question spaceboy YJ Wrangler Technical Forum 19 08-05-2009 06:18 AM
6spd trans drain gamble71 TJ Wrangler Technical Forum 3 12-07-2008 06:11 AM
Trans Pan W/drain Zeep TJ Wrangler Technical Forum 7 10-23-2008 05:43 PM
Trans Fill and Drain Plugs.. RVA_TJ06 TJ Wrangler Technical Forum 1 07-02-2008 10:50 PM
trans drain bolt? jboy416 TJ Wrangler Technical Forum 10 01-23-2008 04:34 AM
