JK spring replacement - JeepForum.com
 1Likes
  • 1 Post By propped1
post #1 of 5 Old 04-18-2019, 06:34 PM Thread Starter
RustyC0755
Does anyone happen to know if springs from a '15 will fit '08? I need to replace mine and someone is donating some from a '15.
RustyC0755 is offline
post #2 of 5 Old 04-22-2019, 01:30 PM
propped1
propped1's Avatar
All JK stock springs fit all JKs. There are various spring rates for 2dr v 4dr v sport v rubi.... but they will all work. A 4dr rubi spring is the stiffest. Almost all aftermarket spring manufacturers are better quality springs than stock.
I am curious why you are need to replace springs.... break one? I bet its shocks you need to replace.
RubiconFreedom likes this.
4" lift, PR 44, PR 60, 5.13, 37 Toyo MT, ATX Slabs, Skids, PSC Big Bore, 2Way
propped1 is offline
post #3 of 5 Old 04-22-2019, 01:48 PM
RubiconFreedom
RubiconFreedom's Avatar
2017 JK Wrangler
Perhaps the jeep is too spongy as coil springs tend to sag or budge over time. Plus if one knows the springs tag numbers maybe they just want to upgrade. Anything below 17AC (front) or 56AA (rear) could use a bit stiffer coil. Even with an upgrade to the 10A of Rubicon Recon coils can offer a significant spring rate as well as a minimal lift.
Semi-Retired Sr. Mechanical Assembler & Sr. Quality Assurance Inspector for Aerospace Industry
RubiconFreedom is offline
post #4 of 5 Old 04-23-2019, 07:16 AM
propped1
propped1's Avatar
I have seen sag issues from aftermarket spring manufacturers, I have heard of broken coils.... But a spongy ride is not the coil. Each coil bears a different weight and does different things in suspension cycle. Usually one will break, not all 4 get spongy. See a lean. Thats a coil. If its just vague ride and spongyness, its a shock (s). Especially in the JK. The coils dont take as much abuse since there is a seperate shock controlling the cycle. Now if a shock isnt working? And you keep driving on it and all the compression/rebound is on the spring. The spring breaks, but it wasnt the springs fault.
The Stock JK shocks should be changed every 40-50K. They are not great. If you have aftermarket shocks and a lift, I havent seen many shocks make it past 40-50 either. Lots fail at 25/30. Sooner if you really beat on them. I bent a shaft on a rear brand new Fox 2.0 adjustable that had about 2000 miles on it. Wiped out the bearing and seals. Had it rebuilt. Had 5160 bilsteins before on 33.5s doing Easy medium offroading.... 27K and the fronts wouldnt rebound. Just fancy limit straps. If you have a stock 08 with 150K and still running the stock junk.... things are going to break.
The best thing you can do for ride is get an aftermarket spring (Teraflex leveling springs are very good quality and stiffer than factory at the same height), and a quality monotube shock. With all the junk JK owners throw on their rigs, they get heavy. I weighed mine for shock tuning. 5067 lbs no back seat, nothing in it. Full tank of gas. Me not in it. Me and my offroad stuff and a cooler? 5600lb rig. Its a 2dr. Some of these 4 drs you see are pushing 6200-6500 lbs with kit and a passenger or two. Good shocks, changed frequently.
propped1 is offline
post #5 of 5 Old 05-05-2019, 05:11 PM
Pine_Cat
Pine_Cat's Avatar
Sounds great, but a lot of folks are probably interested in your non-descript triple-rate coils
2017 JK Sahara (my Smartcar)
2011 KK Liberty (H&R lift springs, OldManEmu shocks/struts, skinny 32)
2009 Kia Sorento (H&R springs, ToyTec strut spacers, OldManEmu shocks/struts, skinny 31)
2006 TJ budget LCG prerunner (see profile)
2006 Chevy Trailblazer (EXT lift, Nth LJ 4.5" springs + Monroe rear coilovers, skinny 32)
1998 Dodge Durango (SuspMax & Roadmaster lifts, rear Truetrac, skinny 32)
Pine_Cat is offline
Coil Spring Replacement for 2000 Jeep Grand Cherokee? pctech WJ Grand Cherokee Forum 5 04-13-2019 07:29 PM
Leaf Spring Bushing Replacement: does Prothane need an outer metal shell HunterS Jeep CJ Forum 1 02-17-2019 10:59 AM
Replacement Leaf Spring Bushings for the Large, REAR eyelet of the FRONT spring Tim Damnit Jeep CJ Forum 9 10-05-2018 05:17 PM
Stock Shock, Strut, Spring replacement 09 Sahara gogogooch JK Wrangler Technical Forum 9 07-09-2018 12:05 PM
Call me stupid, tell me I didn't search the threads-too bad I did. AAl vs RLS HornedFrogHooah XJ Cherokee Technical Forum 23 04-24-2010 12:33 PM
