JK Infinity Audio Woofer speaker replacement - JeepForum.com
 1Likes
  • 1 Post By Thunderstrike
post #1 of 9 Old 03-14-2020, 08:34 PM Thread Starter
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Is there a way to just replace the woofer speaker in the rear woofer enclosure that will return a better sound?
I see some replacement speakers at Crutchfield -- any experience with below woofer replacements?
Rockford Fosgate P3SD4-8, $169
dual 4-ohm voice coils
50-150 watts RMS power range
Rockford Fosgate P3SD2-8, $169
Punch Stage 3 shallow 8" subwoofer with dual 2-ohm voice coils
Memphis Audio 15-PRX8D4, $99
Power Reference Series 8" dual 4-ohm voice coil component subwoofer
Alpine S-W8D4, $119
S-Series 8" subwoofer with dual 4-ohm voice coils
power handling: 300 watts RMS (150 watts per coil)
grille not included
Kicker CompRT 43CWRT81, $159
CompRT shallow-mount 8" subwoofer with dual 1-ohm voice coils
injection-molded polypropylene cone with rubber surround
power range: 100-300 watts RMS
frequency response: 30-500 Hz
2009 JK Rubicon. 2019 Mustang GT 6 Spd DD
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine, LCA & Evap Skid; Rock Hard Gas Tank Skid; Warn Stainless Diff Skids, Uniden 520XL CB, Aeroforce Interceptor, Valentine 1, Baja Designs Squadron-R Pro Fog Pocket.
Ouray - TJ-8/07
Moab - TJ: 4/06, 5/08, JK: 4/09, 5/11, 4/13, 5/16, 4/17, 5/18
Rubicon - TJ-9/08
Pics at
Thunderstrike is offline
post #2 of 9 Old 03-15-2020, 06:57 AM
jabsther
2010 JK Wrangler
I replaced just the sub speaker in the 10 JKU enclosure.
Since I already had the other speakers replaced with Polk Audio, I replaced the sub with the same brand. Only thing that I did need to do was trim the plastic a little to get the sub cover flush again.
Did notice difference. Trying to figure how to describe it, but now notice two or more tones where it would sound closer to one long tone in the sub on the same song.
jabsther is offline
post #3 of 9 Old 03-15-2020, 07:29 AM Thread Starter
Thunderstrike
2009 JK Wrangler
Do you mind posting a pic? Thanks for the reply.
Ouray - TJ-8/07
Rubicon - TJ-9/08
Pics at
post #4 of 9 Old 03-16-2020, 05:14 AM
jabsther
2010 JK Wrangler
Took at angle to show that the cover is almost flush.
jabsther is offline
post #5 of 9 Old 03-16-2020, 03:11 PM Thread Starter
Thunderstrike
2009 JK Wrangler
Very nice. Looks OEM, great job with the trimming you did.
Ouray - TJ-8/07
Rubicon - TJ-9/08
Pics at
post #6 of 9 Old 03-19-2020, 02:26 PM
terpsmandan
I went with this one. Also filled the box with polyfil but did not go with the peel-n-seal.
https://www.wranglerforum.com/f274/s...nt-921921.html
terpsmandan is offline
post #7 of 9 Old 03-19-2020, 04:25 PM Thread Starter
Thunderstrike
2009 JK Wrangler
Going w Pioneer.
Ouray - TJ-8/07
Rubicon - TJ-9/08
Pics at
post #8 of 9 Old 03-27-2020, 08:13 PM
Ricky D
Ricky D's Avatar
I went with the Pioneer TS-SW2002D2. Fit perfect under the stock grill. I filled the space behind it with poly-fil. Sounds much cleaner than the OEM but it's not going to register on any richter scales, at least not paired with the stock amp.
Ricky D is offline
post #9 of 9 Old 03-28-2020, 07:10 AM Thread Starter
Thunderstrike
2009 JK Wrangler
Pioneer TS-SW2002D2 is in route. Looking forward to installing it.
BTW, where is the stock amp located and what is the option to upgrade to get better woofer sound?
Ricky D likes this.
Ouray - TJ-8/07
Rubicon - TJ-9/08
Pics at
