JK front passenger seat removal - JeepForum.com
post #1 of 17 Old 02-27-2007, 05:50 PM Thread Starter
Maine45
2014 JK Wrangler
JK Sahara 2 door, need help with connector
Have removed seat bolts 18mm and seat belt T45 now down to the connector.
Must unplug electrical connector under the seat.
Anyone know how connector comes apart.
Going to Sebring FL. races and need seat out so I will have place to sleep at the track.
Maine45 is offline
post #2 of 17 Old 02-27-2007, 05:52 PM
jeepers3
Guest
You realize of course that if you remove the passenger front seat, you have to take it to the dealer to have the seat re-installed properly because the passenger airbag sensor will need to be recalibrated, and only the dealer can do it.
This is true even if you just loosen the bolts, which you have already done - so now I guess you are screwed.
If I were you, I would leave that seat he hell alone.
jeepers3 is offline
post #3 of 17 Old 02-27-2007, 06:28 PM Thread Starter
Maine45
2014 JK Wrangler
Knew passenger airbag sensor would have to be recalibrated. Don't carry passenger in my Jeep have other cars for that.
Maine45 is offline
post #4 of 17 Old 02-27-2007, 06:39 PM
Evil_Ed
Most Mopar connectors have a bar you need to pull out, and then a snap to lift up to disconnect it...like a red bar that pulls out?
Failing that...you can always just cut the wires..?
Especially if you never have a passenger, may as well have the airbag professionally removed. Provided you don't set it off or otherwise destroy it, you can always put it back in later...
Evil_Ed is offline
post #5 of 17 Old 02-27-2007, 11:24 PM
jeepers3
Guest
Total speculation - but I wouldn't be surprised if there is a law somewhere about disabling or removing airbags from cars. A while back they had they key thing you could use to turn it off if a child is up there or whatever - which is why they came up with these occupant classification system things.
I dunno - just a guess. The govt is always trying to increase its power and intrude on our lives - this would be just another way for it to unconstitutionally assert itself.
jeepers3 is offline
post #6 of 17 Old 02-28-2007, 09:04 AM
nota4re
nota4re's Avatar
Well, OK, I think some clarification.
First, I do not think the dealer is necessary to re-install the seat "properly". When you're done, simply bolt it back in and torque the bolts if you want to be totally proper. Re-connect the connector.
Second, you can remove the seat and connector (IMO), but just don't ever turn the key on when the connector is disconnected. The computer (upon ignition on sequence) will perform a self-diagnostic check of sensors and will be very disappointed not to hear back from the passenger seat. This will trip a code and this code typically is not resettable by the owner with battery disconnects, etc. (DCX would consider this a major fault code and wants the dealer to look at it.)
In brief, do what you want with the seat, just get it installed/connected before the computer discovers something was changed. You'll be OK.
UltraMount CB Ant. Mount for the JK
'07 White 4-door Rubi
nota4re is offline
post #7 of 17 Old 02-28-2007, 06:01 PM Thread Starter
Maine45
2014 JK Wrangler
Thanks for all your help.
The connector was a squeeze and pull. Now have red light on dash that tell that there is no airbag for passenger. That ok the dealer can recalibrat when I trade it in. Now have Jeep configurated the way I want.
JK Sahara 2dr Green Metallic, Dual Top, Trailer Group, LS Diff, 18" Wheels
Maine45 is offline
post #8 of 17 Old 07-27-2010, 06:32 PM
Five0retired
2010 JK Wrangler
Seat removal for Rhino Liner
....Well i just found a Rhino Liner installer who will install the Rhino Guard for $500.00, BUT he says I have to bring the jeep to him stripped,..... top off, rear seat and passenger seat removed. From what I am reading here do I bring the jeep to the dealer and ask them to strip the seat?
Five0retired is offline
post #9 of 17 Old 07-28-2010, 01:54 PM
krutj
krutj's Avatar
2009 JK Wrangler
Just take it to the dealer after the bedlining, have them recal the airbag.
-- Joel --
krutj is offline
post #10 of 17 Old 07-28-2010, 02:13 PM
Croce
Croce's Avatar
2009 JK Wrangler
Dont mean to hi-jack the thread, But i needed to remove some bolts on the rear seat and seatbelt to install a seat cover. That wont make a difference with the air bags right since it was the rear seats?
2009 Jeep JK Sahara Unlimited | Smittybilt XRC Rock Guards | Smittybilt SRC Front Bumper | Rockcrusher Front D30 Diff Cover | KC Hilities Daylighters | Rancho Oil Pan Cover | BMD Evap Skid | AEV Snorkel
Mirror Flip | Daystar dash | Painted Sahara Rims | Seat mounted Mag-lites | Gutter Grill inserts | Smittybilt Seat covers | Vent Mirrors | Spray Can-Bed Liner and Interior Paint
Any fool can know. The point is to understand- Einstein
Croce is offline
post #11 of 17 Old 07-28-2010, 02:46 PM
nyrangersfan19
nyrangersfan19's Avatar
What exactly would happen if one weren't to recalibrate the airbag? I was planning on just removing the front seat, spraying the bedliner, then putting it back in without starting the vehicle in between. Any problem with that?
nyrangersfan19 is offline
post #12 of 17 Old 07-28-2010, 03:03 PM
jstrubberg
2009 JK Wrangler
If the airbag isn't calibrated correctly, it won't deploy.
That's a problem for your passenger, but I seriously doubt it's illegal. Most vehicles have a switch to allow you to disable a passenger side bag anyway. I doubt the car manufacturers included a switch enabling you to break a law.
jstrubberg is offline
post #13 of 17 Old 07-28-2010, 03:06 PM
tkob1060
2016 WK
You do NOT need to bring the jeep to dealer to recalibrate the airbag BUT you must disconnect the battery and wait 2 minutes before unplugging the air bags, then when you reinstall disconnect the battery before plugging the seat in again. I know this for a fact, I had mine out for linex install.
tkob1060 is offline
post #14 of 17 Old 07-28-2010, 03:13 PM
tkob1060
2016 WK
no the rear seat has no air bags. did you get the bolts all out yet? If you need to remove the bolts on the 4 dr rear seat you have to take the front leg bolts out first, then flip the seat up and you can get to the rear bolts, use a long 6 or 10 inch extension on a 3/4 drive ratchet.
tkob1060 is offline
post #15 of 17 Old 07-28-2010, 03:48 PM
Croce
Croce's Avatar
2009 JK Wrangler
Thanks for the response, just wanted to double check
Love the Rhino-Line/LineX btw, Looks great
Croce is offline
air bag disconnect , JK Wrangler , seat removal , wrangler
94 yj passenger front axle removal RustyzChopShop YJ Wrangler Technical Forum 16 10-03-2009 06:07 PM
How to get front passenger seat out? Eddiesnuts TJ Wrangler Technical Forum 4 04-28-2009 08:31 AM
YJ Right Front (passenger) Axle Removal silverwolf636 YJ Wrangler Technical Forum 2 01-30-2009 04:36 PM
passenger front seat patiller TJ Wrangler Technical Forum 4 11-27-2007 07:27 PM
Passenger seat removal innerchi TJ Wrangler Technical Forum 4 03-04-2007 06:36 AM
