Jk 2012 3.6 strange loud front noise - JeepForum.com
post #1 of 20 Old 03-04-2015, 08:25 AM Thread Starter
rallyman78
After a mud trail my JKU 2012 3.6 auto starts to have a strange noise in front of the engine.
Here it is how this sound look like: https://www.youtube.com/watch?v=IdTjgBln8nw
It sounds like a siren. Bystanders turn and stare. Aside from the noise there are no ill effects, but I can stand it no longer.
The noise does not seem to be coming from the steering pump -- it doesn't change with steering load and it seems to be coming from higher up, near the top of the Pentastar 3.6-liter V6. I don't think is the alternator too.
Anyone had the same issue?
Tks!
Felipe Schultz
JKU 2012 3.6 auto
2.5" coil spacers
285x70x17 BF KM2
19x9 Procomp wheels
power off road front bumper
power off road rear bumper
dynastar ball joints
10000lbs ekron eletric winch
hella rally 1000 lights
rallyman78 is offline
post #2 of 20 Old 03-04-2015, 08:36 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Pull the belt and check all of the pulleys by hand. Idler and tensioner especially
no loose, no crunchy or tight.
Check airbox for obstruction / wet air filter. Make sure temp sensor is well seated in air duct.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #3 of 20 Old 03-04-2015, 11:49 AM Thread Starter
rallyman78
tks jwmbishop! I will do that! does you already have the same problem? Does anyone have or had the same issue?
post #4 of 20 Old 03-04-2015, 12:24 PM
rubicon1000
The issue is a pulley bearing they are not sealed and sand and grit gets in there and destroys them. I had the same issue on my 2012 when I lived in Florida had it changed under-warranty.
'12 unlimited sport S, 3.73, trac loc, towing package, rubicon unlimited springs and shocks
SOLD 03 Rubicon , nv 3550 ,4'' RC lift ,1'' RC MM lift, 1.25'' body lift, HD rear bumper, hummer snorkel cap with buick airbox and custom piping, 265/75 r 16 tread wright retread mud tires on stock rubicon wheels, smitty built 8k winch, cobra cb radio, rrc front bumper, pre-runner rear bumper, HID headlights in Hella housings
rubicon1000 is offline
post #5 of 20 Old 03-04-2015, 01:48 PM
JoeCitizen
BTW, nice bumper.
JoeCitizen is offline
post #6 of 20 Old 03-04-2015, 02:20 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Not on the JK - but the F250 started sounding like that and 125 miles later (while towing the JK) - the belt shredded and the idler pulley launched...
post #7 of 20 Old 03-05-2015, 08:09 AM
SlyDawg64
SlyDawg64's Avatar
2014 JK Wrangler
Myself and a number of friends have had the same problem after dirty/dusty wheeling and found that the water pump bearing was going out. Took it to dealer who replaced it under warranty with no problem.
New:
2014 JKU Rubicon, Copperhead Pearl, 3" TerraFlex lift, Toyo MT 35x12.5x18 tires, Warn Powerplant,
Old:
2010 JK Rubicon, 2 dr., 3" Terraflex lift and adjustable rear track bar, Toyo 35x12.5 tires, custom bumpers, Warn Powerplant, KC lights, B&M trans cooler, etc.
SlyDawg64 is offline
post #8 of 20 Old 03-05-2015, 08:21 AM Thread Starter
rallyman78
Did they change only the bearing or the water pump?
post #9 of 20 Old 03-05-2015, 08:26 AM Thread Starter
rallyman78
Do you know which pulley can be?
post #10 of 20 Old 03-05-2015, 08:41 PM Thread Starter
rallyman78
Went to mechanics shop today and listen With stetoscope to the idler pulley, and we think os one of it. Just order the pulley
post #11 of 20 Old 03-05-2015, 08:52 PM
rich6700
There are two idler pulleys, replace them both
rich6700 is offline
post #12 of 20 Old 03-06-2015, 11:50 AM
Paio2012
I replaced the three pulleys and the alternator bearing and the noise continued. It was the water pump where the noise was coming from. Replaced yesterday with 49000Km. Looks fine now.
2012 Sport S - JK Wrangler
Deep Forest Green
Paio2012 is offline
post #13 of 20 Old 03-06-2015, 11:54 AM
Paio2012
Just in case. The Jeep 2012 on pulleys are the same of the Citroen Picasso 2.0. See part number VKM4913. They are much cheaper comparing to the ones provided by Mopar in Brazil.
Deep Forest Green
Paio2012 is offline
post #14 of 20 Old 03-06-2015, 11:56 AM
Paio2012
There is no bearing on the water pump. It is a quality issue not solved yet by the factory.
Deep Forest Green
Paio2012 is offline
post #15 of 20 Old 03-06-2015, 12:19 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
DITTO!!! But again - with the belt off you can usually FEEL the bad one...
Thanks - I love interchange info!
no SERVICEABLE bearings....
alternator , idler pulley , noise , serpentine belt , water pump
