Jeep JK Fuse Box Map Layout Diagram - Page 3 - JeepForum.com
 1Likes
post #31 of 48 Old 06-11-2015, 04:56 AM
aramac
Help
can anyone give information about fuse panel in 2008 jeep liberty . question does it have two fuse panels ? is one under the other , and how does it come apart . I have stock fog lights and they are not working both bulbs are new But fuse box does not show fuse for fog lights . HELP
aramac is offline
post #32 of 48 Old 06-11-2015, 11:32 AM
1222
RIP John
1222's Avatar
Please post your questions in the Jeep Liberty Forums, this forum is for JKs only. Thanks.
Here is a direct link for you. KK Liberty Forum
(2011-2016)
1222 is offline
post #33 of 48 Old 12-03-2015, 10:07 AM
HippyMoose
Any issues pulling the main fuse to keep thieves from stealing the Jeep JK like while staying at a hotel?
HippyMoose is offline
post #34 of 48 Old 01-09-2016, 09:49 PM
mudstah
Electrical Issues....
Driving home in POURING rain, With no grill, my lights started to flicker. Then I had NOTHING. No steering wheel controls, no lights, no directionals, no runners, no wipers. All I had were my LED spots... Needless to say, I got home safely, but WTF? Any advise will be appreciated.
mudstah is offline
post #35 of 48 Old 01-11-2016, 01:14 PM
ShanMcD12
My locks stopped working, is that M38?
ShanMcD12 is offline
post #36 of 48 Old 01-18-2016, 07:46 PM
Kpjr2181
My locks stopped working this week as well. The M38 was clearly blown when I took it out but when I try to replace it the new fuse sparks immediately and blows without even getting it completely in. Not sure what I'm doing wrong.
Kpjr2181 is offline
post #37 of 48 Old 01-18-2016, 08:42 PM
ronjenx
ronjenx's Avatar
Fuse M38 protects the door lock relay coils on the pc board inside the TIPM.
Fuse M38 protects the circuits that leave the TIPM to actuate the lock actuators.
The door lock switches are MUX, and are not protected by a fuse.
It's most likely the short that is blowing the fuse is between the TIPM and the door locks.
Try disconnecting each door to see if one of them is causing the short. Don't forget the tail gate.
If, after all the doors are disconnected, it continues to blow the fuse, you will have to check each lock/unlock wire for continuity to ground.
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
post #38 of 48 Old 04-13-2017, 02:19 AM
4768338
Hey Guys
i have a Problem. I replaced my original Headunit to a Android Headunit (works well) and yesterday i added the amp (ETON DSP 8).
I made a special adapter-harness that i can use the original whires and plugs without changing anything so i can easy replays everything and itīs original again.
Anyhow- i made something wrong. My Radio is notworking anymore and my inlights are also dark. Checking the Voltage at the radio-connector - it says 0V.
So i checked the Fuses (M12, M10 and M11), all fine. Now i checkt the Voltage between the Fuse-Socket an the ground of the Car - also 0V. So there must be some kind like a pre-Fuse wich may be broken?!
Has anyone an idea? Itīs a 2013 EU-Model, 2.8 Diesel.
Thanks for helping!!! Itīs soooo quiet an dark in my car.....
4768338 is offline
post #39 of 48 Old 04-25-2017, 01:19 PM
SBinTN
Sadly, my 2012 jeep has had a couple of things quit working all at once. The horn, the radio controls on the back side of the steering wheel, and the right rear turn signal. I'm headed to the auto parts store to get a light for the turn signal, since that's the easiest solution for that. Judging from what I've read so far, I know which ones *might* be the ones for the horn and turn signal, but what about the radio controls on the steering wheel?
Any advice would be appreciated. Thanks!
SBinTN is offline
post #40 of 48 Old 05-08-2017, 06:52 AM
jeepwrnglr92
2015 JK Wrangler
Is this still the same fuse block for a 2015 JKU? I looks similar to mine.
It is hard to read on the Jeep so this really helps a lot. Thank you.
2015 Jeep Wrangler JKU "Tank" Sport S
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline
post #41 of 48 Old 05-09-2017, 08:36 PM
dirtyjeep31
I have a question. Looks like same fuse box for 2015 JK unlimited sport. I installed halo lights and halo fog lights tapped into M9 and M14. They were shutting off when I turned off the jeep and then one day got to work and the lights stayed on after the jeep was turned off. Do M9 and M14 go to a relay that could be bad now? Also notice my climate control knobs inside the jeep If i push them on and get the little orange light they do not turn off when the jeep is turned off. The orange lights stay on. What could be going on now?
Any help appreciated Tom
dirtyjeep31 is offline
post #42 of 48 Old 07-25-2017, 10:54 AM
WaterRat72
WaterRat72's Avatar
2015 JK Wrangler
Anyone know how to get J13 out??? Does just the fuse come out or the whole yellow piece that surrounds that particular fuse?
I'm guessing this fuse is out since my car isn't starting all of the sudden even when I try to jump off my auxiliary batt.
WaterRat72 is offline
post #43 of 48 Old 09-19-2017, 10:14 AM
Cavi
2014 JK Wrangler
I just reset my J13 and I do not think it is really meant to be fully removed unless it really is bad. One thing, on 2014 rubicon, other than the radio it also controls the fob system so you have to unlock the car with the key then the alarm will go off when you open the door and the fob will not work, but start the car and the alarm will go off....
Cavi is offline
post #44 of 48 Old 11-14-2017, 08:57 AM
joebbaseball
Hi all,
I'm having an issue with my 2011 JK domelight. Hoping someone on hear can help. The only way for the light to work is by manually hitting the buttons on it. The cluster knows when all 3 doors are open. The light itself has been tested and works. The light is also getting power from the yellow wire. I've tried changing the turn signal stalk. Nothing seems to be working. At this point I feel like it has to be the cluster, but I really don't want to go there as it's quite expensive. Thanks in advance to anyone that can offer some advise! This problem is REALLY bothering me.
Joe
joebbaseball is offline
post #45 of 48 Old 01-09-2018, 04:18 PM
KB6BRC
Bro - you rock!!! Thank you!!!
KB6BRC is offline
87 fuse box diagram cuzinjay YJ Wrangler Technical Forum 4 11-11-2009 12:31 PM
A/C to fuse box diagram? czjeeper YJ Wrangler Technical Forum 2 10-15-2008 02:08 AM
FUSE BOX DIAGRAM FOR 2002 JEEP WRANGLER (Sahara) TJ MichMarine78 TJ Wrangler Technical Forum 2 02-28-2007 03:58 PM
'97 fuse diagram? famicom21 TJ Wrangler Technical Forum 2 10-28-2006 08:56 PM
fuse panel layout djpslim TJ Wrangler Technical Forum 0 12-09-2004 09:58 PM
