Issues after air bag recall - JeepForum.com
post #1 of 5 Old 01-20-2020, 04:53 PM Thread Starter
punkin
Had my airbag recall completed and now I am having issues. When I pulled out into traffic it was not shifting right but it straightened out and went back to normal so just thought it was a fluke. Then when leaving my house, driving up a hill it would not shift and it was losing power and I didnt think I was going to make it up the hill and then it started working. Got out on the highway, my traction control light came on and when I would turn on my cruise control the light would come on to indicate it was on but when I would try to set it, it would turn off! It has been fine for a few days and now the same crap on the way home from work. Havent called the dealership yet. Wanted to hit u all up first. 2013 JK Sport
punkin is offline
post #2 of 5 Old 01-21-2020, 09:28 AM
cranbiz
cranbiz's Avatar
Sounds like you have an intermittent wheel speed sensor. That would do what you are seeing. I'ts most likely a coincidence as the airbag recall won't go anywhere near wheel sensor wiring.
Get a scanner that can read ABS and see what codes you have.
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #3 of 5 Old 01-29-2020, 07:16 AM
arielgs74
arielgs74's Avatar
2016 JK Wrangler
I gotta take mine for the same recall.
I hope it is nothing serious in yours!
Finally back on the 4x4 world!!
Got my Wrangler Unlimited Sahara 2016!
arielgs74 is offline
post #4 of 5 Old 01-30-2020, 07:20 AM Thread Starter
punkin
Well turns out I was due for service and my oil was low. This threw a couple codes and was just protecting itself. Now I just need to figure out why I'm using so much oil between services. Nothing on the garage floor
punkin is offline
post #5 of 5 Old 01-30-2020, 09:24 AM
cranbiz
cranbiz's Avatar
Maybe a cracked oil cooler? Unfortunately, that requires pulling the intake to inspect and/or replace. If you are close to 100K, replacing the plugs also requires pulling the intake, that would be a fine time to inspect the oil cooler.
06 KJ
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
