Intermittent stalling on cold start 2013 JKU - JeepForum.com
post #1 of 10 Old 12-08-2019, 09:03 PM Thread Starter
Geoskier9
Junior Member
Geoskier9's Avatar
Hey guys, I’ve had my JKU for almost 2 years so this is my third winter with it. Almost every time I cold start it in winter it stalls when I put it in reverse (automatic) even when I allow it to reach operating temperature first. I restart it and the RPMs bog down once it’s in gear but it stays running most of the time. It’s been to the dealer (non-jeep) I bought it from a few times and they were at a loss. Any ideas what could cause this? Maybe a torque converter binding up like dropping the clutch?
Geoskier9 is offline
post #2 of 10 Old 12-11-2019, 06:50 PM
222Doc
222Doc's Avatar
Hard to say. TQ is not likely< that would code i would think. just since you dont state anything about the jeep. Is it stock? Large tires and no regear? I could see say in the cold where the dif oil is like tree sap. Say its on 34/35s and stock 3.21:1 gears. Now that tree sap has to work hard to get rolling. as you get it going that oil starts to warm up? A hypothesis.
222Doc is online now
post #3 of 10 Old 12-11-2019, 08:31 PM Thread Starter
Geoskier9
Junior Member
Geoskier9's Avatar
It’s on a 2.5” lift, 33” tires, and stock sport gearing. 90,000 miles. I will try swapping differential and transfer case fluid and see if that helps. Thanks!
post #4 of 10 Old 12-12-2019, 07:27 AM
jtec
jtec's Avatar
2014 JK Wrangler
2 thoughts or questions
When it stalls does the CEL come on?
Does the CEL come on at EVERY start @ 3 seconds then og out?
jtec is offline
post #5 of 10 Old 12-13-2019, 07:43 AM Thread Starter
Geoskier9
Junior Member
Geoskier9's Avatar
Hard to tell, CEL is on all the time for an unrelated p0128. Once I get the thermostat replaced I’ll check back in.
post #6 of 10 Old 12-13-2019, 08:17 AM Thread Starter
Geoskier9
Junior Member
Geoskier9's Avatar
Looking back on a video I took of it, the CEL doesn’t come on when it stalls or when i turned it back on.
post #7 of 10 Old 12-29-2019, 02:12 PM
yanncik358
Have the same issue here with a stock JK 2014
yanncik358 is offline
post #8 of 10 Old 01-03-2020, 10:59 AM
cranbiz
cranbiz's Avatar
It is most likely the Torque Converter. It's a known issue in newer JK's (17-18).
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #9 of 10 Old 04-05-2020, 10:20 AM Thread Starter
Geoskier9
Junior Member
Geoskier9's Avatar
Finally got to the rear diff fluid. Spider gears are destroyed. Possibly the cause? Or just an unrelated issue?
post #10 of 10 Old 04-06-2020, 12:37 PM
cranbiz
cranbiz's Avatar
Unrelated but also a common issue.
06 KJ
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
