If you were to do control arms in stages, which are first? fronts, rears, uppers? - JeepForum.com
post #1 of 7 Old 04-30-2012, 06:03 PM Thread Starter
09YellowJK
2009 JK Wrangler
I think I'm ready to start installing some short adj arms. I can't afford them all at once, so which ones should be priority?
I read somewhere:
1. front lowers
2. rear uppers
3. front uppers
4. rear lowers
Is this here-say, or legit?
Also, when does an adj track bar become important?
2014 JKU Rubicon - In the planning phase
'09 Wrangler "X"(SOLD)-4" Rough Country Lift, 35" Falken All Terrains, 4.88s, D30 w/Aussie Locker Sleeved/Gusseted, D44 w/Detroit TT
09YellowJK is offline
post #2 of 7 Old 04-30-2012, 06:09 PM
paul84043
Good question, subscribed...
paul84043 is offline
post #3 of 7 Old 04-30-2012, 06:24 PM
Hieneken49
I would like to know too, Is there set lift heights that require control arms? I know with the old dodge trucks ir was 3" and over and u needed longer arms. Thats the last vehicle i lifted.
Hieneken49 is offline
post #4 of 7 Old 04-30-2012, 07:01 PM
TheBoss
TheBoss's Avatar
Front lowers, rear lowers, then front uppers and rear uppers as needed. 2 drs will need the front lowers sooner than the 4dr because of the wheelbase. They adjust pinion angle and caster .Trackbars recenter the axle under the vehicle. 2-3" of lift above that your better off with trackbar brackets to keep the track bar parallel to the drag link with a draglink flip kit. These two items in combination will keep your Jeep more in control at speed. Used mostly with taller 3.5" and up lifts.
TheBoss is offline
post #5 of 7 Old 05-01-2012, 08:20 AM Thread Starter
09YellowJK
2009 JK Wrangler
I'm comparing different companies lift kits in the gradual upgrades. It does seem to be sold in a graduating level including both lowers, prior to including uppers.
post #6 of 7 Old 05-01-2012, 09:44 AM
222Doc
222Doc's Avatar
well the stock arms are rather tough on JK's. Fact is you are more likely to break alot of other things first.
2 door at 3.5 its rear first. To rotate the pinion up to aline the cardan. BUT, if you get rears control arms rear you can set the rear back just a bit 1/2-5/8 35;s fit no pinch cutting needed, pluss it gives the rear a better stance. fronts to adjust caster if needed. I still run stock fronts. If I do replace the front say i do bend one, I would get Currie.
222Doc is online now
post #7 of 7 Old 05-01-2012, 09:47 AM
Prot
Prot's Avatar
2014 JK Wrangler
I went with eight at once. The advantage of the Polyperformance onces is they can be adjusted while still installed. They improved my stability and helped reduce my susceptibility to cross winds.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
Whats Better, Adjustable Uppers or Lower control arms? gaboy1911 TJ Wrangler Technical Forum 3 09-17-2011 06:24 PM
Combining stock control arms with Johnny Joint control arms alex_c TJ Wrangler Technical Forum 3 09-10-2010 09:55 AM
Buy or Fab uppers control arms? Airborne4X4 TJ Wrangler Technical Forum 6 04-24-2008 05:15 PM
regular control arms vs. heim joint control arms. lucasinpsj TJ Wrangler Technical Forum 7 10-27-2004 02:35 AM
HELP. Control Arms. Uppers vs. lowers. mgering TJ Wrangler Technical Forum 3 04-13-2004 09:44 AM
