How much lift before you need adjustable trackbar? - JeepForum.com
post #1 of 14 Old 12-25-2009, 12:34 AM Thread Starter
crashtom
I have a 2" suspension lift on my 09 unlimited. To get the front and the rear the same height I'm putting a 3/4 inch coil spacer in the front. With the 2" lift I haven't had to touch the trackbar but by putting an additional 3/4 inch lift will I have to go to an adjustable Trackbar or can I get by with the stock? I've read that people go to the adjustable trackbar at 3" and above.
crashtom is offline
post #2 of 14 Old 12-25-2009, 08:57 AM
MattJK09
2009 JK Wrangler
I don't think you will HAVE to have an adj track bar, but it depends on how much your axle shifts. It is usually not noticable by most, but I just ordered one for my 2.5" lift. Just for peace of mind and I already used a trackbar relocation bracket for the rear.
09 X 23S Flame Red 2door, tinted, Black Rock 997's, BFG 32" MT's, grab handles, RR XHD front bumper,BW trail armor,4door springs up front, KC's
MattJK09 is offline
post #3 of 14 Old 12-25-2009, 09:08 AM
RacingRandie
2009 JK Wrangler
I have not changed anything. Put in the lift (2.5") and thats it other than relocating the rear brakeline. I'm afraid to change to much cause it looks good and drives good right now. Start changing to much might get DW and don't want that.
RacingRandie is offline
post #4 of 14 Old 12-25-2009, 09:19 AM
Imped
Imped's Avatar
ANY change in height will result in axle shift. If you do it right, centering the axles will only make it drive better.
OlllllllO
IndyORV
Imped is offline
post #5 of 14 Old 12-25-2009, 09:22 AM
Swagger
Swagger's Avatar
Any lift at all will start to move the axles off center. I had a 2.5" BB and additional .75" for winch and bumper for over a year with no issues at all. Front axles were 1/4 " to one side more than the other, which means it's only 1/8" out. So I re-centeresd the steering wheel and moved on.
Swagger is offline
post #6 of 14 Old 12-25-2009, 10:04 AM
Xtremjeepn
You should never need an adjustable track bar. Adjustable track bars have become a pet peeve of mine. They were created by lift fabricators that can't do math or geometry.
"X" amount of lift height should require a BRACKET in "Y" location to get proper geometry and handling. Fab guys found it easier to just make an adjustable rod to connect two points, over moving the mounting locations to the proper place.
The other issue with adjustable track bars is this. You lift the jeep, then "center" the axle at rest. that mean a longer track bar was used. So at full stuff you axle is off center again and can miss it's bumpstop target. Not to mention what the steering geometry is doing at full stuff. I would almost rather have my axle off center at rest than at compression!!!! A slightly off center axle going down the road is fine. (twisted axle will steer funny, offset is fine).
FWIW I am at 4.5" of lift and my track bars are a "fixed" length. Why? Because the geometry was done correctly by AEV.
Cole Ford
Xtremjeepn is offline
post #7 of 14 Old 12-26-2009, 12:09 AM Thread Starter
crashtom
Thanks for the help. After my 2 inch lift the front is still even and the rear is 1/8 to the right. Would the rear relocation bracket take care of this and which one?
Thanks
crashtom is offline
post #8 of 14 Old 12-26-2009, 08:04 AM
MattJK09
2009 JK Wrangler
Thanks
I went with the Teraflex rear bracket for like $30 and it did the job for me. Sturdy design, bolts to the frame.
MattJK09 is offline
post #9 of 14 Old 12-26-2009, 07:23 PM
RockyClymer
RockyClymer's Avatar
While I won't ( and cannot) argue with xtremjeepin, almost 95 percent of my miles (personal driving habit and style - not a lot of offroad) miles are done at highway or normal road speeds - the remaining 5 pecent off-road are at a very low, reduced speed where having an adj track bar that creates the geometry issues at full compression or full extension is just not an issue for me regarding handling... - they work fine at my normal driving speeds and do not create stress issues like brackets at very low off road speeds. just my 2 cents on adj. track bars
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #10 of 14 Old 12-26-2009, 07:59 PM
Xtremjeepn
Originally Posted by RockyClymer View Post
.....almost 95 percent of my miles (personal driving habit and style - not a lot of offroad) miles are done at highway or normal road speeds - the remaining 5 pecent off-road are at a very low, reduced speed where having an adj track bar that creates the geometry issues at full compression or full extension is just not an issue for me regarding handling... -
The full compression was only part of the issue.
You should read this.
http://www.aev-conversions.com/12thi...lve_things.pdf
With a lifted suspension you really need to lift the "roll centers" front and rear to at least match what you changed with the added lift height. So the 2.5" springs should require *AT LEAST" a 2.5" raise in the axle end mounting location front and rear just to return the roll centers back to stock. Keep in mind you also added larger tires, which move the COG farther away from the pavement so the chance should compensate for those too. So a 35" tire lifts the Jeep about 1.5" over a 32" tire. So you should have a bracket that raises the axle end mount by about 4" over stock to make it handle right at road speeds. This will make a HUGE difference in the way it handles and how the ESP reacts to it. It will also make it LESS PRONE TO ROLLING on the road.
Cole Ford
post #11 of 14 Old 12-27-2009, 08:26 PM
RockyClymer
I've read it many times and have no beefs with what is said - and my opinion remains the same given my situation - if you want to pick the flysh!t out of pepper - then do it...
NRA Life member
post #12 of 14 Old 12-27-2009, 09:36 PM
Xtremjeepn
If you are okay with **** in your food, or don't know any better. Then I guess it works for you.
Cole Ford
post #13 of 14 Old 12-27-2009, 10:12 PM
McKBrew
McKBrew's Avatar
JK Wrangler
I've read a few of these threads. The basic gist I get is that the more money you spend on a lift, the better off you are. So are budget wheelers really taking that much of a risk using something that is not an expensive, custom engineered system?
Are there any published accident rates or documentation that say that a particular brand or method of lift is inherently more dangerous?
McKBrew is offline
post #14 of 14 Old 12-27-2009, 10:21 PM
Xtremjeepn
Money really has nothing to do with it. There are some very expensive lifts with poor engineering.
I actually took off a $3,000 set up to put on my AEV set up and am much more impressed with the handling of the less expensive set up.
I think there are a lot of fabricators out there just making jeeps tallere with no real understanding of the engineering.
When you do an apples to apples comparison of the AEV lift cost it really is no more expensive than other suspensions, it just completets the package to make it work right. Some cheap lifts are just parts, not complete systems.
Cole Ford
Will I need a trackbar relocation bracket with rear adjustable trackbar FLATFENDER54 TJ Wrangler Technical Forum 3 02-05-2009 04:35 PM
Adjustable Trackbar missionAvs TJ Wrangler Technical Forum 8 06-20-2008 07:26 AM
Would An Adjustable Trackbar Help? dspmans_04_X TJ Wrangler Technical Forum 8 09-22-2006 04:36 PM
Adjustable trackbar necessary? phreek TJ Wrangler Technical Forum 2 09-21-2006 02:24 PM
Best adjustable trackbar for 2.5" lift anthrUTtj TJ Wrangler Technical Forum 14 01-29-2006 08:33 PM
