How to decide between 5.13 and 5.38 gears? - JeepForum.com
post #1 of 3 Old 07-23-2011, 12:20 PM Thread Starter
AcidRaiN
2011 JK Wrangler
I have an 11 Rubicon. I plan on a lift and 35's. It is an automatic. Is there any benefit with going with 5.13's over 5.38's? Are they priced about the same?
Thanks!
AcidRaiN is offline
post #2 of 3 Old 07-23-2011, 06:04 PM
jstrubberg
2009 JK Wrangler
Pretty close to no difference at all. Either will work just fine.
jstrubberg is offline
post #3 of 3 Old 07-23-2011, 06:33 PM
Warlord2
If you ever think you will get bigger tires or tow then go with the 5.38s
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
Yukon 4.88 gears on back order, what gears would be just as good? N2SPD TJ Wrangler Technical Forum 20 02-06-2011 08:19 PM
Can't decide between 4.56 or 4.88 gears lilyellowjeep TJ Wrangler Technical Forum 29 01-16-2010 10:06 AM
Chattanooga, Tn members: Can i drive your jeep...need to decide on gears! TJ_ITmgr TJ Wrangler Technical Forum 37 05-23-2009 07:03 PM
Will a differnece be noticed from 3.07 gears and 33" tires to 3.73 gears chaznad TJ Wrangler Technical Forum 9 08-26-2005 10:54 AM
can't decide on gears scherf68 TJ Wrangler Technical Forum 11 07-25-2005 01:49 PM
