Hot oil light... - JeepForum.com
post #1 of 31 Old 07-31-2010, 06:38 PM Thread Starter
1222
RIP John
1222's Avatar
Hot oil light...
I was wheeling in the Nevada high desert the other day (107 deg) and while climbing a moderate grade with a lot of twisting sharp soft dirt turns the hot oil light came on with loud chiming too.
I turned the Jeep around as soon as I could and went down a short distance looking for a place in the pines to turn it off and rest. It was off for only maybe 5 minutes when I started it to see if the light went off. It did but we stayed there for 15 more minutes to let it cool more.
I read somewhere on here where somebody said the Jeep would go into limp mode when the light comes on. Mine didnít. Has anyone else had that experience and if so did yours go into limp mode?
Yes I know I need an oil cooler and itís just because Iím in the lazy mode that thereís not one on now. Hopefully that will change very soon.
(2011-2016)
1222 is offline
post #2 of 31 Old 07-31-2010, 09:01 PM
TheShift
TheShift's Avatar
2010 JK Wrangler
Limp mode..
srs... did you get the recall fixed?
I realize you said you were in the desert and it was hot as fuk...
maybe it was false?..............
or was that recall only for the 10's... i already forget lol
TheShift is offline
post #3 of 31 Old 07-31-2010, 09:13 PM
Jiblet
I don't think shutting it off is the correct response... 'cuz you stop the circulation.
For some reason I am thinking you are supposed to idle and maybe turn on the AC.
Were you in 4-lo?
Anyone know what temp triggers the warning?
OP: now go get that dang cooler!!
Jiblet is offline
post #4 of 31 Old 07-31-2010, 09:16 PM Thread Starter
1222
RIP John
1222's Avatar
Yup, limp mode.
Did the recall re-flash thatís why it came on. I doubt it was false.
I donít think the recall pertains to the 2010ís.
(2011-2016)
1222 is offline
post #5 of 31 Old 07-31-2010, 09:35 PM
TheShift
TheShift's Avatar
2010 JK Wrangler
Limp mode... i know... it's just funny to me...
TheShift is offline
post #6 of 31 Old 07-31-2010, 10:17 PM
joe002
Originally Posted by 1222 View Post
I was wheeling in the Nevada high desert the other day (107 deg) and while climbing a moderate grade with a lot of twisting sharp soft dirt turns the hot oil light came on with loud chiming too....
Were you in 4 Low or 4 High? Also did you have O/D turned off?
2008 Rubicon - 2 Door - Flame Red - Automatic - MyGIG - Power Group - Deep Tint.
AEV Pintlers, BFG KM2s 35x12.50x17, Bulldog Fab Stubby Bump, Currie F/R Adj Trac Bars, Daystar Upper Dash, FireStik FireFly antenna, Kilby Rear Shock Skids, LoD Sig Stubby Bump, Midland 75-822 CB, Mopar Filler Door & Locking Gas Cap, Rancho LCA Skids, Rancho Oil Pan Armor, Riddler Diff Covers, custom Rubi Sliders, Sylvania X-treme Headlights, TeraFlex 2.5" Spring Lift, Warn PowerPlant HD, Woods Evap Can Relo, Woods SS Relo, Yukon 5.38s
joe002 is offline
post #7 of 31 Old 08-01-2010, 02:11 AM Thread Starter
1222
RIP John
1222's Avatar
I was in 4 high but wasnít going very fast. It was shifting a lot and I did think of putting it in 4 low but I never had a problem before so I thought I could get away with it. Dumb, I know.
(2011-2016)
1222 is offline
post #8 of 31 Old 08-01-2010, 03:03 AM
Warlord2
Tranny coolers are almost required for around here. Something that will help it cool would be to turn on the heater, it will act like a 2nd radiator. Helps a lot for towing as well. If your just driving in dirt then use 2wd, it puts much less stress on the engine and will have much more hp at the wheels. I do desert driving quite a bit, lots of fixed up prerunners dont even have 4wd and desert is pretty much all they do. A tranny cooler would prolong the life of your transmission and I highly recommend getting one if your doing this type of offroading. Im sure 4low would help but obviously wouldnt be practical if you want to go fast and really isnt good on the TC if its not needed.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #9 of 31 Old 08-01-2010, 03:27 AM Thread Starter
1222
RIP John
1222's Avatar
I know I need a tranny cooler and have mentioned it before. The problem is I always seem to put things off until something happens and then I have to do whatever.
Will be putting one on soon. Iíve been wheeling in the desert for almost 24 years now and never needed one. All of my previous Jeeps have been manuals. This is my first auto and Iím learning as I go.
(2011-2016)
1222 is offline
post #10 of 31 Old 08-01-2010, 04:06 AM
Warlord2
oh my bad, I thought you mentioned oil cooler. Those are 2 different things. I dont think the jeep has a oil temp sensor on it, I believe a dummy light will turn on if the pressure gets too low though. Maybe thats what will put the jeep into limp mode like your talking about.
Warlord2 is offline
post #11 of 31 Old 08-01-2010, 04:14 AM Thread Starter
1222
RIP John
1222's Avatar
Iím not sure if itís supposed to go into limp mode with hot tranny oil or not. Itís just that somewhere a while back somebody mentioned it. I would guess it wonít since mine didnít. Oh well, just curious.
(2011-2016)
1222 is offline
post #12 of 31 Old 08-01-2010, 06:43 AM
tavic
2010 JK Wrangler
Manufacturer Procedure for Hot Oil:
If this HOTOIL message turns on, stop the vehicle and run engine at idle or faster with transmission in neutral until message turns off.
It'll basically occur when heavy towing or sever off-road conditions. But you definitely want keep the engine running to circulate the oil through the factory oil cooler.
tavic is offline
post #13 of 31 Old 08-01-2010, 07:25 AM
JIMBOX
JIMBOX's Avatar
2018 LJ Wrangler
You have a JK AUTO
You need an aux cooler
If you have A/C with tranny cooler, turn on A/C, engine fan comes on automatic and will help cool tranny fluid
Never climb off-road hills in 4hi, always use 4lo--it takes load off torque converter and tranny bands, the tranny will operate up to 45 į cooler in 4lo
Did I say install aux cooler ??
Here's the aux cooler in front of the A/C condenser, which also has a "minute"
Tranny cooler init
When you install an aux cooler there and turn on thr A/C, the engine fan will pull air thru--to cool--it works great
JIMBO
Firecracker Red 2dr RUBICON--2018
Stinger Yellow 2016 RAM/Hemi/8spd auto 4x4
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #14 of 31 Old 08-01-2010, 08:07 AM
SoCalJK
SoCalJK's Avatar
Had exactly the same issue wheeling in the desert. Fitted a tranny cooler after that. I wheeled in the desert for 3 years before they did the recall without a problem. Guess I was cooking the tranny then.
2007 Sahara Unlimited
4x4, Auto, Jeep Green, Tow Package, Soft top, 3 inch spring lift, MBRP Catback
SoCalJK is offline
post #15 of 31 Old 08-01-2010, 08:08 AM
vonhef
2010 JK Wrangler
Originally Posted by JIMBOX View Post
....When you install an aux cooler there and turn on thr A/C, the engine fan will pull air thru--to cool--it works great
JIMBO
Are you saying that the engine fan isn't already running? He said he was in the desert at 107 deg... I would think that his radiator fan would already be running. If so... seems to me that turning the AC on would introduce additional heat thru the radiator and into the factory transmission cooler.
vonhef is offline
automatic transmission , hot oil light , JK Wrangler , oil temp warning , transmission temp warning , wrangler
keep blowing tail light, turning singnals and interrior light fueses on my TJ bigtime13 TJ Wrangler Technical Forum 1 11-06-2009 06:34 PM
Interior light issues - dome light and wiring mess liminalhigh YJ Wrangler Technical Forum 0 07-20-2009 07:47 AM
Turn signal dash light stuck on, warning chime, no shift light. bmlawless TJ Wrangler Technical Forum 7 10-21-2008 08:29 AM
brake light/Hazard light fuse blows as soon as you install it! jeffro123 YJ Wrangler Technical Forum 6 08-23-2005 10:57 AM
