gurgling/scratching in transmission - JeepForum.com
post #1 of 4 Old 09-16-2015, 12:02 AM Thread Starter
YourAlterEgo
2009 JK Wrangler
My transmission seems to be making an odd noise, it only occurs in 4th and 6th gear when applying the gas. there is no sound in neutral, or any other gear, but with as the engine revs up, the sounds becomes more apparent. if my foot is off the gas and coasting it sounds like normal. The noise is hard to explain, it sounds almost like a gurgling/scratching sort of sound, almost as if its bogging down. there does not seem to be any negative effect on acceleration or anything else, its just making a noise.
I don't want something small to turn into a couple thousand in repairs. Any ideas anyone?
I have a 2009 JK X, with a 6 speed manual transmission, 87K miles.
YourAlterEgo is offline
post #2 of 4 Old 09-16-2015, 01:43 PM
duneslider
duneslider's Avatar
Have you changed the oil in the transmission recently? I would think starting there would make sense. Drain the oil and see what it says. If all is good, refill with fresh lube and see if the noise is still there.
duneslider is offline
post #3 of 4 Old 09-17-2015, 08:13 PM
goodwrenchdave
dropping the oil never hurts and you can get a good idea of wear or even damage by how much "beard" or "fragments (hopefully none)" the magnetic plug grows
have you tried:
if you slightly push on the shifter to the right, up down while accelerating- does the noise go away? if it does- Make sure the shifter boot (lower) isn't causing too much tension (sometimes the trans mounts loosen/rip from wear and the movement causes the boot to overstretch)- most boot problems cause popping out of gear.....but ya never know. something to look at
goodwrenchdave is offline
post #4 of 4 Old 09-18-2015, 12:23 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hey YourAlterEgo,
Unfortunately, I could not locate any TSBs that relate to your vehicle. Does this noise happen every time you accelerate or does it only happen intermittently? I would advise you to have your vehicle formally diagnosed at an FCA certified dealership. Private message me if you have any further questions.
JeepCares is online now
noise , transmission
