Getting a Soft top - Page 2 - JeepForum.com
post #16 of 25 Old 11-22-2010, 06:56 AM
McKBrew
McKBrew's Avatar
JK Wrangler
How much did you pay for the top without hardware? Hope you got a great deal on it to make up for all of the things it didn't come with.
McKBrew is offline
post #17 of 25 Old 11-22-2010, 07:18 AM
ls6tt
2010 JK Wrangler
lets clear up some confusion first.
you dont NEED the surrounds for the top to work, but you need them to prevent leaks and gaps.
not sure if a 2010 soft top will work on 07-09 but an 07-09 will fit on all years. the top was changed in 2010 to not have the tucking drop rail.
with that said, you need to make sure to get surrounds from 07-09 if you are running an 07-09 top.
top prices seem to be dropping, im seeing them around 300 with obos on other forums with all hardware included. hold out for a complete set up and save yourself the trouble.
as for leaks, my soft top on my 2010 is from a 2007, i have zero leaks and ive been in some heavy rainstorms.
ls6tt is offline
post #18 of 25 Old 11-22-2010, 09:56 AM
ncb
ncb's Avatar
The side rear windows would be useless with out door surrounds. The leading edges of the side rear soft top windows would severely flap around with out surrounds. Also the sunrider portion wouldn't have the latches to clip into with out door surrounds. Running a soft top with out door surrounds wouldn't be safe.
ncb is offline
post #19 of 25 Old 11-22-2010, 03:23 PM
ls6tt
2010 JK Wrangler
interesting, given i run it that way quiet often.
ls6tt is offline
post #20 of 25 Old 11-22-2010, 03:26 PM
ncb
ncb's Avatar
Originally Posted by ls6tt View Post
interesting, given i run it that way quite often.
Just my opinion.
ncb is offline
post #21 of 25 Old 11-22-2010, 04:21 PM Thread Starter
zamball
2009 JK Wrangler
I got the top for $150.00. It has the bows,soft top all windows. It also came with the tailgate brackets and the knobs do tighten it down.
2009 JK Rubicon 2.5" RC lift | Drop in K&N filter | Bully Dog GT Gas Tuner
2007 WK CRD 3.0 Stock for now...
zamball is offline
post #22 of 25 Old 11-22-2010, 05:08 PM
ls6tt
2010 JK Wrangler
hunt ebay and craigslist and you may get lucky, just make sure its the right version 07-09 for the 07-09 soft top and 10 brackets for the 10 soft top.
ls6tt is offline
post #23 of 25 Old 11-22-2010, 05:11 PM
nwbronco
nwbronco's Avatar
2014 JK Wrangler
nwbronco is offline
post #24 of 25 Old 02-20-2011, 01:44 PM Thread Starter
zamball
2009 JK Wrangler
edit
zamball is offline
post #25 of 25 Old 02-20-2011, 01:45 PM Thread Starter
zamball
2009 JK Wrangler
On the installation guide the Torx screw "W", what size is it. I was going to install it today and noticed I did not have the four screws. They are the screws which attach the bow mount brackets to the sports bar.
Thanks
zamball is offline
door surrounds , JK Wrangler , soft top , wrangler
Bestop Tinted Soft Top Windows and Factory Soft Top firehawk_1989 JK Wrangler Technical Forum 2 05-21-2010 10:10 AM
Bestop makes 2 piece soft doors which match with Factory soft top? AROSETO TJ Wrangler Technical Forum 9 02-23-2010 11:41 AM
Need soft top - Whats the scoop on Viking soft tops? Q-01 TJ Wrangler Technical Forum 3 01-11-2008 07:36 AM
adding soft uppers to soft half doors? chrisvr6 TJ Wrangler Technical Forum 4 03-22-2007 03:18 PM
re: do soft top windows from older best top soft tops fit 03 wrangler?? skaboyy TJ Wrangler Technical Forum 3 06-12-2004 01:59 PM
