fog light switch - JeepForum.com
post #1 of 7 Old 08-16-2011, 05:48 PM Thread Starter
wallyJEEPIN
fog light switch
Where would you mount a switch for after market fog lamps on a wrangler x? Any ideas or pics will help thanks
wallyJEEPIN is offline
post #2 of 7 Old 08-16-2011, 06:01 PM
1222
RIP John
1222's Avatar
One of the more popular and easier places is on the left side front panel just above the speaker. Just open the driver side door and pop off the side panel were you can then hook up the wires to the switch.
1222 is offline
post #3 of 7 Old 08-16-2011, 07:33 PM
OH9JK
OH9JK's Avatar
2009 JK Wrangler
OH9JK is offline
post #4 of 7 Old 08-16-2011, 07:56 PM
Blu-Jacket
2009 JK Wrangler
There is ample room in the left side of the dash. Here's a pic of my IPF switch.
Blu-Jacket is offline
post #5 of 7 Old 08-16-2011, 08:00 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Like 1222 said, a good place is above the speaker.
Easy access by pulling off the side cover and there is a hole through to the inside of the cowl that you can pull wires through.
You can see the wires coming through the hole in the thread that OH9JK linked.
Jim
JLC08JK is offline
post #6 of 7 Old 08-16-2011, 08:08 PM
Vin
Vin's Avatar
I'm pretty sure that's where the directions for the Mopar Aux lights tell you to put them also. Very easy access to the engine bay throught the firewall at that point.
Vin is offline
post #7 of 7 Old 08-16-2011, 09:50 PM
ThunderFoot
ThunderFoot's Avatar
Here are a couple of options that don't require drilling.
Rugged Ridge Pillar Switch Mount
sPod by Precision Designs
You'll need to select a separate link inside these links.
The first is just the switches but the sPod has a separate box with relays and fuses that connect straight to the battery.
I have the sPod and, while it is a bit pricey, I like it for its versatility and ease of adding accessories. Once the Source is installed, you'd just have to run two wires from the accessory to the box. The switches are never bothered with after installation except to turn them on and off.
2007 JK Wrangler X • Steel Blue Metalic • Gray Cloth • 3.8L V6 • 6MT
Freedom Top (Black) • Soft Top (Black) • 285/75R17 TOYO Open Country AT • Pro-Comp 3036 17x9 Alloy Wheels • TUFFY Security Drawer • Delta Quad-Bar Xenon Headlights • JK 6-Switch sPOD Source • SuperChips Flashpaq Tune
Diode Dynamics LED License Plate • Cobra 75 WX ST • 4' Wilson Antenna • AIRAID SynthaMax Cool Air Dam Intake System • Hella FF 500 Driving Lights • Hella Black Magic Driving Lights • Smittybilt G.E.A.R. Tailgate Cover
9" Billet Antenna • RR XHD Bumpers Fore & Aft with Storage Ends and Spare Tyre Carrier • XRC8 Winch • 2.5" Pro-Comp Suspension • Bilstein Shocks • RECON LED Smoked Turn Signals & Fender Lens
Colorado Jeep Club Member #1958
ThunderFoot is offline
2003 TJ - Moving fog light switch from MFS to toggle switch TJeep_1999 TJ Wrangler Technical Forum 10 08-05-2015 04:07 PM
Using factory Defrost switch to control door switch/dome light aestrad1 TJ Wrangler Technical Forum 4 01-29-2011 07:00 PM
can a safety switch be wired into parking light switch? kornonthekob99 YJ Wrangler Technical Forum 8 11-09-2010 01:50 PM
want to change fog light panel switch with 4 wires to rocker switch with 3 terminals lomondpeak TJ Wrangler Technical Forum 6 11-28-2009 09:21 PM
Replacing fog light stalk switch with dash mounted switch? Imped TJ Wrangler Technical Forum 7 08-31-2008 12:58 PM
