Essential accessories for a new owner - Page 2 - JeepForum.com
post #16 of 31 Old 07-22-2010, 10:18 AM
McKBrew
McKBrew's Avatar
JK Wrangler
Good luck on keeping the sand of of the Jeep. I've got sand all over my seats, carpet, under carpet, etc... from last weekend.
McKBrew is offline
post #17 of 31 Old 07-22-2010, 10:23 AM
little_Jeep
little_Jeep's Avatar
Originally Posted by jeffself View Post
These are all great suggestions! I've just ordered the Rugged Ridge floor mats for the front and rear from Northridge 4x4. Hitting the beach in about a week and want to control the sand as much as possible. Will try and get my basic kit set up before hitting the beach.
I have a feeling the wife is going to take my credit cards away from me!
There isn't sand anyway within 500 miles of me so I have never wheeled in sand. However, wheel-n in sand is different than wheel-n in dirt or rock. Maybe a few guys/gals here that have experience in sand, can share some sand driving tips.
little_Jeep is offline
post #18 of 31 Old 07-22-2010, 10:27 AM
Amesbear
When I had my Jeep (RIP) I always had the following:
Jumper cables
Camp Shovel
Tow Straps
Socket Set
Ponchos
Foil Blankets
Candles
Flashlight
Matches (in an aspirin bottle)
I'd also recommend a fire extinguisher.
Amesbear is offline
post #19 of 31 Old 07-22-2010, 10:27 AM Thread Starter
jeffself
jeffself's Avatar
2010 JK Wrangler
Fortunately for me, I'm 3 hrs from the mountains and only a little over an hour from riding on the beach. I'll mostly do the sand, but I definitely look forward to hitting the mountains either this fall or next summer.
May have to arrange a little Jeep excursion around a Virginia Tech football game!
2010 4dr Rubicon. Temporarily stock.
jeffself is offline
post #20 of 31 Old 07-22-2010, 10:32 AM
little_Jeep
Jumper cables
Camp Shovel
Tow Straps
Socket Set
Ponchos
Foil Blankets
Candles
Flashlight
FYI, Stick matches painted with clear finger nail polish are pretty much water proof.
post #21 of 31 Old 07-22-2010, 11:10 AM
1222
RIP John
1222's Avatar
I also carry a top rated tire plug kit. Not only is it good for your vehicle but others too. Iíve used it several times over the years. Of course youíll need an air compressor which I feel is a must have anyway.
(2011-2016)
1222 is offline
post #22 of 31 Old 07-23-2010, 11:47 AM
krip
krip's Avatar
You are in my area of the World.... so I suspect that the terrian we have is about the same.
CB radio (don't waste your time with a handheld) there are some real nice mini CB that work great for about $50.00 (Cobra M19 at Wally World, but there are others to choose from).
CB antenna, Firestic II, or Wilson (Pilot Truck Stops have a great selection of these antenna). For wheel-n, you want antenna to stick above the roof line only a couple inches, any taller and you will just knock it off in brush. Usually a 3 foot fiberglass antenna works perfect if mounted about tail light high. If you want to use CB for highway use, purchase a second taller antenna.
Great tips. I like the idea of teh Cobra 19 (especially the small size) Curious to know where and how you mounted the unit inside your jeep?
Thanks
Krip
krip is offline
post #23 of 31 Old 07-23-2010, 01:11 PM
little_Jeep
Thanks
Krip
I actually have the Cobra 19 in my tow rig and I have it setup to be a loaner when needed... I zip tie it to a roll bar, and have a long power cord that plugs into cigerette lighter, add my magnetic antenna, and a newbie without a CB now has a CB. You can mount it under the dash, beside the console, there is a mount that you can mount it on dash by driver's side door, basically, you can mount it anywhere if you also attach a $10.00 external speaker so you can hear what is being said.
post #24 of 31 Old 07-23-2010, 11:00 PM
fernjack
fernjack's Avatar
That has been a trip saver for me in the past ....... I strongly second this for sure
07' Rubi Unlimited 6spd. , Rescue green #64 CDN , 35x12.5 mudders
Rick .
fernjack is offline
post #25 of 31 Old 07-24-2010, 02:31 AM
Mudhound0530
1988 MJ Comanche
Maglite and cb
88 MJ 94 XJ
09 JKRU SOLD
14 Chevy Silverado Quad Cab 4x4
Mudhound0530 is offline
post #26 of 31 Old 11-19-2015, 09:16 AM
Silvercreek
Just as a note, I think the word essential is a very mis-used word. Of course the aftermarket retailers are taking advantage of it in their advertising. Check out what you get when you search Jeep Wrangler Essentials.
Silvercreek is offline
post #27 of 31 Old 11-19-2015, 09:47 AM
cranbiz
cranbiz's Avatar
I mounted my CB using the Rugged Ridge Footman loop mount. It's holding a Bearcat 990 radio and it's solid.
cranbiz is offline
post #28 of 31 Old 11-19-2015, 10:05 AM
jay-h
Pocket code scanner
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is online now
post #29 of 31 Old 11-19-2015, 10:22 AM
fastfreddie
Essential?
GraBars.
After your sandy, play time is through, make sure you hose out the sand that accumulates in the nooks and crannies of the undercarriage. The sand will act like a localized sandblaster due to vibrations, not to mention it being a moisture trap.
fastfreddie is offline
post #30 of 31 Old 11-19-2015, 12:12 PM
motoguy1251
To me the most essential tools for a Jeep is a Torque wrench and preventative maintenance.
motoguy1251 is offline
accessories , essential accessories , JK Wrangler , wrangler
Are Cooling Upgrades Essential For Stock Jeep bertram31 TJ Wrangler Technical Forum 9 09-02-2009 06:13 PM
List of essential trail gear/equipment Jonman03 TJ Wrangler Technical Forum 11 03-01-2009 03:50 PM
Most essential/important mod... 98 Sahara TJ Wrangler Technical Forum 12 10-23-2007 09:43 AM
An example of why skids are essential... Jerry All-Bran TJ Wrangler Technical Forum 18 12-03-2005 04:39 PM
What skid plates are essential for offroading? And HID headlights? diveguy TJ Wrangler Technical Forum 22 12-23-2004 07:40 AM
