Door wiring harness disconnect - JeepForum.com
post #1 of 5 Old 06-06-2009, 07:16 AM Thread Starter
kobecoyote
Guest
Hello,
I am tryng to take my doors off for the first time and I Can't get the darn wring harness to dsconnect? I'm sure t's easy but I can't get t. Any help would be great, it's a beautiful day here.
kobecoyote is offline
post #2 of 5 Old 06-06-2009, 07:17 AM
wrestlerobx
wrestlerobx's Avatar
Originally Posted by kobecoyote View Post
Hello,
just use a small flathead screw driver to help disconnect the actually clip in the connector that holds it together sometimes it doesnt want to budge
wrestlerobx is offline
post #3 of 5 Old 06-06-2009, 07:21 AM Thread Starter
kobecoyote
Guest
Just so I'm not jamming the screwdrver in the wrong spot, I have slid the red locking thing to the right. Now I just push just below that with the screw driver? They sure don't give you much slack on those wires.
post #4 of 5 Old 06-06-2009, 08:33 AM
wrestlerobx
that is correct that is how i do it when i cant get it to budge and it is more of a lifting motion of the clip
post #5 of 5 Old 06-06-2009, 09:09 AM
USAntigoon
Retired from Forum
slide the red lock over, then press on the bottom flat part of the connector to release and pull slightly..
USAntigoon is offline
Center Console/Wiring Disconnect CAPTAIN TJ Wrangler Technical Forum 4 12-20-2009 10:40 AM
wiring harness jerseyrider1119 YJ Wrangler Technical Forum 7 11-02-2009 10:20 PM
Remove/Disconnect Door Chime? bruker TJ Wrangler Technical Forum 21 07-20-2008 08:12 AM
Disconnect Wiring Harness- Hard Top removal mfdevine JK Wrangler Technical Forum 4 04-14-2008 09:53 AM
How To Disconnect Hard Top Wire Harness? Tommy R TJ Wrangler Technical Forum 15 06-21-2007 09:57 PM
