Door rattle - JeepForum.com
post #1 of 11 Old 11-29-2010, 12:24 PM Thread Starter
Robbish87
2010 JK Wrangler
Door rattle
So I have a rattle on the passenger side and thought I'd try the tape on the striker plate fix but I don't understand how u do it. A. The tape doesn't stick due to grease and B. The second u close the door the tape comes apart anyways. Am I missin something here?
Robbish87 is offline
post #2 of 11 Old 11-29-2010, 12:27 PM
jstrubberg
2009 JK Wrangler
THe tape goes on the loop attached to the door pillar, not the latch inside the door panel.
jstrubberg is offline
post #3 of 11 Old 11-29-2010, 01:32 PM Thread Starter
Robbish87
2010 JK Wrangler
Yeah that's where I placed it but it wasn't tight it could spin around cuz of grease and after one close of the door it came apart
post #4 of 11 Old 11-29-2010, 01:34 PM
1AAdam
^^ X2. if u are putting it on the striker like u explained above there will be grease on it from the latch mechanism on the door. u will have to get this off for the tape to stick (again, as u said). if the tape isn't staying on then there prob is some more grease on there that u just need to clean off. not sure what to use to get it off but sure someone on here will know. i'm really surprised jeep let this one go but hey can't be too surprised i guess.
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #5 of 11 Old 11-30-2010, 03:31 AM
VaRaven
2010 JK Wrangler
The door needs to be adjusted
VaRaven is offline
post #6 of 11 Old 11-30-2010, 11:00 AM
rwunsche
If they have to adjust the door, do they have to cut the paint around the hinges? Or do you mean the door latch mechanism itself?
This rattle is wicked bad on my 2011 Unlimited (driver's side). I plan to let the dealer deal with it when it goes in for its first oil change. I don't like the idea of them having to adjust hinges though, so I'm hoping you meant the latch assembly.
rwunsche is offline
post #7 of 11 Old 11-30-2010, 11:56 AM
mthomp83
2010 JK Wrangler
so i took my jeep to the dealership and they took care of this issue no problem....they have a "bulletin" out for this issue
it's easier if you just take it to the dealer, it only took them like 30 minutes
2010 JK Rubicon - Flame Red - 3.5" AEV Premium Suspension Lift w/ Bilstein 5100 Shocks, 17" AEV Savegre Wheels, 35x12.50 r17 BFG KM2's - Rugged Ridge XHD Modular Front Bumper w/ 10,500lb Winch - Rugged Ridge XHD Rear Bumper w/ Swing Out Tire Carrier - Poison Spyder JK Evap Skid Plate - KC Slimlite Long Range
mthomp83 is offline
post #8 of 11 Old 02-16-2011, 06:53 PM
ARRazor
ARRazor's Avatar
2011 JK Wrangler
If you want to go tape route.....
Try this...
2011 Sport Unlimited
Custom Blended Graphite Grey CamoLiner Premium Protective Coating with Kevlar Micro Pulp
Smittybilt SRC Classic Front Bumper
Smittybilt SRC Side Armor / Rock Guards
Smittybilt XRC 10,000 Lb. Winch
(4) 6" KC "Flame Thrower" Lights
BushWacker Fender Flares
4" Pro Comp Lift
Pro Comp Tie Rod Stabilizer
(5) 17" KMC XD Hoss Rims
(5) 35x12.50 Nitto Trail Grappler M/T
ARRazor is offline
post #9 of 11 Old 02-16-2011, 08:00 PM
scottka
What'd they do to it? Just grease it?
scottka is offline
post #10 of 11 Old 02-16-2011, 08:22 PM
mthomp83
2010 JK Wrangler
they told me that they did but honestly i'm not sure....when i left the dealership i heard no rattle and for about 2 weeks i did not hear a rattle but low and behold, it started to rattle again. i wrapped the catches like everyone said above and i have had no issues since....probably have to replace the tape every few months depending on how much you keep the doors on
if you take it to the dealer, it will just be a waste of time, take the 10 minutes to put on the tape and you will be more than happy and wont even notice it
mthomp83 is offline
post #11 of 11 Old 02-17-2011, 07:30 AM
JKommuter
2009 JK Wrangler
TSB 23-024-08 covers this. Basically grease the latch mechanism on the door. It worked for me.
Post 84 on this thread https://www.jeepforum.com/forum/f96/b...21/index6.html has the TSB attached.
JKommuter is offline
door rattle , JK Wrangler , noise from door pillar , wrangler
Door Rattle TSB mtbr JK Wrangler Technical Forum 16 02-05-2009 05:35 PM
Door rattle even on the 08s CRASH0577 JK Wrangler Technical Forum 27 04-27-2008 07:06 PM
door rattle.. as well as another one.. esad_b TJ Wrangler Technical Forum 8 04-25-2008 03:12 PM
Door rattle samsonitesamson YJ Wrangler Technical Forum 12 04-19-2008 03:15 PM
Rear Door Rattle steve1173 JK Wrangler Technical Forum 5 12-23-2007 01:40 PM
