DIY Door Cart Write-up - JeepForum.com
post #1 of 13 Old 10-19-2014, 02:36 PM Thread Starter
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
I've seen a few out there, but thought I'd post my own... Pretty simple...
Parts List:
- (4) 30" 2x6
- (2) 18" 2x6
- (2) 4" 2x4
- (2) Furniture Dolly ($20 at Home Depot)
- (26) #10 3" Wood screws
Tools Required:
- Screw Gun
- Circular Saw
It's pretty straight forward as you can see, so I'll spare the step-by-step process. I thought about putting some L-brackets and/or supports, but its actually pretty solid as is. I'll probably also get some foam padding to put on the contact points, thought the wood is soft enough that its not going to really damage the paint. For the rear doors, you'll notice the blocks that keep the door from sliding.
I got all the supplies from Home Depot for both these and the Hardtop dolly for under $100!
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #2 of 13 Old 10-19-2014, 07:42 PM
BlackJeep2013
That's a slick set up. Maybe you could pass on your dimensions, I might give this a go thanks
BlackJeep2013 is offline
post #3 of 13 Old 10-20-2014, 12:54 AM
LeighP
Nice job, I like how they nest when not in use.
Regards,
Leigh
2013 JK Overland/Sahara 3.6L
LeighP is offline
post #4 of 13 Old 10-20-2014, 12:32 PM Thread Starter
MusicMaverick
2014 JK Wrangler
Sure, have the dimensions up on top... But basically 2 30" vertical 2x6's, screwed the 18" 2x6 across the top, and center it on the dolly's.
Currently: '14 JKU
post #5 of 13 Old 10-20-2014, 12:52 PM
duneslider
duneslider's Avatar
Throw some bungies, rope, or straps on there to keep them from falling off.
duneslider is offline
post #6 of 13 Old 10-20-2014, 01:23 PM Thread Starter
MusicMaverick
2014 JK Wrangler
I might, just for added security, but doesn't really need it. There's a lot of inward leaning pressure already.
Currently: '14 JKU
post #7 of 13 Old 10-20-2014, 04:01 PM
duneslider
duneslider's Avatar
You apparently don't have children
post #8 of 13 Old 10-20-2014, 05:30 PM Thread Starter
MusicMaverick
2014 JK Wrangler
Haha... very true... Good point!
Currently: '14 JKU
post #9 of 13 Old 10-21-2014, 07:47 AM
jeepwrnglr92
2015 JK Wrangler
Nice job, I like this. I can get the dollies from Harbor freight cheep locally.
One questions: Why does one have block and one does not on the bottom?
Might I add wrap the wood in carpet so not to mar the soft plastic. Not sure if someone else mentioned that or not.
Ya bungees or a strap would be good too. Bump and that's all she wrote.
Maybe I am missing something simple here.
Thanx for the idea.
edit: Never mind I see the back doors are a bit smaller and will wobble off as it were.
2015 Jeep Wrangler JKU "Tank" Sport S
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline
post #10 of 13 Old 10-21-2014, 11:03 AM Thread Starter
MusicMaverick
2014 JK Wrangler
Exactly, the back doors kept sliding down, I spaced it a little bit so that the weld pinching can slide between. Very secure now... Yeah, I have some foam pipe wrap that I'll probably use, just have to get some contact cement. Though unless we get another heat wave, not sure the doors will be coming off again this year...
Currently: '14 JKU
post #11 of 13 Old 07-02-2019, 08:31 AM
1a9c7m9
2015 JK Wrangler
Thanks
Thanks for sharing this post and your parts list. I was able to get to Home Depot just after 9pm and had one of these built for my front doors by 10:30.
I joined the forum just so I could say thanks. I was pretty bummed yesterday after setting my doors on the garage floor carpet and my young daughter WALKED on them. Thankfully, she's only four, so she doesn't weigh much, but I was definitely not wanting to risk leaving them on the ground.
1a9c7m9 is offline
post #12 of 13 Old 07-02-2019, 05:08 PM
R3dRid3r
Very cool.
Love the design and functionality.
"You'll Shoot Your Eye Out"
R3dRid3r is offline
post #13 of 13 Old 08-22-2019, 01:22 PM
zjeb67
2014 JK Wrangler
Just what I was looking for
Gonna try with a Harbor Freight dolly
zjeb67 is offline
