Diagnosing Death Wobble and Non-DW Wobbles and Shimmies Videos - JeepForum.com
post #1 of 17 Old 06-02-2012, 01:21 AM Thread Starter
planman
Thanks to all Mod erators
planman's Avatar
Several people have requested videos that explain Death Wobble and diagnosis/inspection.
The videos are kind of long at 18-19 minutes each. Hopefully, they are thorough enough to help.
Here is the link to my Death Wobble Diagnosis thread with written explanations:
https://www.jeepforum.com/forum/f96/d...bbles-1052221/
planman is offline
post #2 of 17 Old 06-03-2012, 05:23 PM Thread Starter
planman
planman's Avatar
If you have questions, you can post either here or in the longer Death Wobble diagnosis thread.
planman is offline
post #3 of 17 Old 06-11-2012, 03:05 PM
JamzAre
I took delivery of a 2012 Rubicon and wondered if death wobble remained a concern with that jeep. The bolt part number is M14X1.50X70.00. Does the 14 refer to the same 14 mm bolt that caused the problem? If so where does one buy Grade 8, shouldered 9/16 bolts as recommended previously?
Thanks to all.
1. Once more into the breach, dear friends,
2. De gustibus non est disputandum.
JamzAre is offline
post #4 of 17 Old 06-11-2012, 03:12 PM
SubAtomicGenius
SubAtomicGenius's Avatar
2011 JK Wrangler
Great stuff, Planman, thanks from all of us in the Jeep community!
SubAtomicGenius is offline
post #5 of 17 Old 06-11-2012, 03:14 PM
LIJeepJC
Originally Posted by JamzAre
I took delivery of a 2012 Rubicon and wondered if death wobble remained a concern with that jeep. The bolt part number is M14X1.50X70.00. Does the 14 refer to the same 14 mm bolt that caused the problem? If so where does one buy Grade 8, shouldered 9/16” bolts as recommended previously?
Thanks to all.
I could be wrong but I believe this is a non issue on the newest models. Anyone exp this in a post 2010 JK?
LIJeepJC is offline
post #6 of 17 Old 06-11-2012, 08:17 PM
SubAtomicGenius
2011 JK Wrangler
This will always be an issue with solid front axles in this configuration. While proper torque of the trackbar is essencial, the smaller 14mm bolt exacerbates the problem. Torques on the trackbar (and other areas illustrated by Planman's video) should be checked frequently. As a note, I just replaced all of my 14mm bolts with shouldered 9/16" Grade-8 bolts three weeks ago and I found my trackbar mounts (axle side) slightly wallowed out, making the 9/16" bolts loose as the 14mm were in the first place. I'm planning on beefing up the mount in a couple of weeks when I start my re-gear process.
post #7 of 17 Old 06-11-2012, 10:47 PM
rah2eq
1978 CJ5
Thanks
Planman, your death wobble diagnostic is extremely informative, thank you so much for looking out for all of our Jeeps! I have had a really weird vibration at slow speeds, it's not death wobble but I'll go through your checklist anyway, I'll likely come across the culprit!
rah2eq is offline
post #8 of 17 Old 06-12-2012, 07:49 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Great video planman!
The DW thread is also.
JeepCares is online now
post #9 of 17 Old 06-12-2012, 08:21 AM
drpericak
Is Death Wobble a very common thing that happens? I'm planning on getting a JKU pretty soon, and I know if it happened to me without seeing a DW video, I'd freak out. Is this something that occurs more often if you really use your jeep for off roading, or is it a random thing? (I watched some of the videos, but not everything.)
drpericak is offline
post #10 of 17 Old 06-12-2012, 08:31 AM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Death Wobble can happen to any solid axle vehicle with a link suspension. In unmodified Jeeps, it is pretty rare. If you modify your suspension with longer, adjustable links, it can happen more frequently....however, when it does, it's usually due to a combination improper installation and insufficient maintenance.
During installation all components should be torqued to proper specification, and after a hard wheeling trip, the operator should inspect and re-torque suspension components. In theory, a properly maintained suspension shouldn't have a Death Wobble episode.
Need parts? Need product advice? Contact Jason at
ArticRubi is offline
post #11 of 17 Old 06-12-2012, 08:40 AM Thread Starter
planman
planman's Avatar
DW happens due to worn/damaged parts, improper installations, and poor maintenance.
It doesn't matter if a jeep is lifted or not. Poor maintenance can result in DW. I have helped diagnose DW sources on many stock JKs, and I have read reports of new JKs with loose trackbar bolts.
Stock or modded, the control arm and trackbar bolts should periodically be retorqued to specs.
planman is offline
post #12 of 17 Old 07-04-2012, 10:11 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
While "most" dw's are cured by resolving trac-bar issues...it should be noted that the other "worn/damaged" parts others spoke of can easily cause the same issue. Just replaced ball joints, never touching my trac-bar, and my death wobble went away instantly. It should be noted, I had a slightly bent "C" and needed an offset joint to put the camber and caster back in spec. Once installed, again, never touching my trac-bar....my death wobble (bad enough it would force me to pull over occasionally) was completely gone. It has been said many times...a good safe number is around 45k for these Jk's when one should start looking at joints. Less if it's been lifted as more stress is put on the weak own joints. Cheers !
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #13 of 17 Old 07-05-2012, 09:19 AM Thread Starter
planman
planman's Avatar
Did you watch the videos?
planman is offline
post #14 of 17 Old 07-05-2012, 06:49 PM
Tomb Raider
Addicted...
Yeah...after I changed out joints, lol. Good info and videos. It was just a note that ball joints CAN cause extreme death wobble.
post #15 of 17 Old 11-20-2013, 05:34 PM
ironman72com
2009 JK Wrangler
Thanks for all the good points on checking for the death wobble. I am planning to get the Grade 8, shouldered 9/16 inch bolt for my track arm as well as a brace. Does this sound like a good fix for DW? I am as planning to get heavy duty upper an lower ball joints. I want to be proactive vs. reactive. I have had this happen to me twice.
ironman72com is offline
Diagnosing Death Wobble and Fixing Non-DW Shimmies and Wobbles planman JK Wrangler Technical Forum 359 10-12-2015 06:28 PM
Diagnosing Death Wobbles with Go Pro mountainkahn JK Wrangler Technical Forum 6 04-15-2012 01:50 PM
Death wobble - Help diagnosing buff531 TJ Wrangler Technical Forum 12 04-29-2011 02:49 PM
Need more help diagnosing Death Wobble TigerSpeed TJ Wrangler Technical Forum 12 12-12-2010 09:18 PM
think I may have had Death wobble/need help diagnosing 1398653 JK Wrangler Technical Forum 11 09-14-2010 06:07 PM
