Page 2 of 2 | 1 | 2 |
LinkBack | Thread Tools |
Originally Posted by jmreagan
View Post
OP, to rule out ball joints jack the front end of the JK up and set it atop some jack stands securely. Use the jack as a back up to the jack stands for redundant safety. Then grab the front tire at 6:00 and 12:00. Yank the tire at the aforementioned positions back and forth. Repeat the process to the other side. If you have no movement with the wheel then your ball joints are fine. This is an easy way to check ball joints and will save you lots of cash IF they check out fine with no movement... instead of throwing money at parts that don't need replacing. Now if you were on 37" tires and had 80K on the odometer I would have mentioned the above ball joint check as well in my previous thread above. But I believe I read you have stock-ish sized tires and no lift if I'm not mistaken. So I didn't mention the ball joint check...
2008 JKU Rubicon
42RLE Auto
Sponsored Links | |||
As usual, everyone has an opinion. Some better than others above, but none from any actual inspection of your rig. Hence, none that mean anything other than you will find on one of the 200,000 pages that mention it.
The good news is that there are probably more 4x4 shops in Denver per capita than anywhere else. And, as was said by some of the more savvy posts above, unless you have considerable expertise, a good 4x4 shop is where you take death wobble. Post in the Colorado forum and ask for a recommendation of a knowledgeable 4x4 shop.
Good luck.
Good luck.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
Tags |
death wobble , lift advice , shocks |
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Posting Rules | |
