Dead Turn Signal and Side Marker - JeepForum.com
post #1 of 8 Old 06-06-2020, 12:09 PM Thread Starter
NIUPonyBoy
NIUPonyBoy's Avatar
My driver side marker died a while ago, my drivers side front turn signal burnt out recently. I got new bulbs for both and neither work.
I cleaned the connections and even replaced the wire harness from the loom to the side marker and still nothing.
I swapped the plugs for both the side marker and the turn signal to the other side and they work there.
I can just wire in jumper wires from the passenger side to the drivers side markers but what is causing the dead turn signal? I want to get that working again.
'15 Expedition EL, '12 Outback,'07 JK, '06 Mustang GT, '05 PowerWagon,'05 Freestar, '02 Yamaha
NIUPonyBoy is offline
post #2 of 8 Old 06-06-2020, 03:47 PM
ronjenx
ronjenx's Avatar
Every time I have had problems with the park/turn signal lights, it has been due to bad ground connections. Rather than trying to trace the ground wire through the bundles, I just run a new ground wire from the socket to the nearest bolt in the body.
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
post #3 of 8 Old 06-06-2020, 08:59 PM Thread Starter
NIUPonyBoy
NIUPonyBoy's Avatar
Thank you. I like it. Sounds like I will do that Monday.
post #4 of 8 Old 06-12-2020, 02:16 AM Thread Starter
NIUPonyBoy
NIUPonyBoy's Avatar
Much appreciated. That fixed both of the lights. Thanks!
post #5 of 8 Old 06-12-2020, 08:32 PM Thread Starter
NIUPonyBoy
NIUPonyBoy's Avatar
After repairing some ground wires it worked perfectly for 2 days... and it’s broke again.
post #6 of 8 Old 06-12-2020, 08:37 PM
ronjenx
ronjenx's Avatar
Check for 12 volts and continuity to ground at the pins in the sockets.
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
post #7 of 8 Old 06-29-2020, 08:17 AM Thread Starter
NIUPonyBoy
NIUPonyBoy's Avatar
Which bold did you use? I’ve done a few bodge wires and ran a local ground to the bumper coupler to the frame. It works intermittently now at least. I want to fix permanently as it really pissing me off. Thanks.
post #8 of 8 Old 06-29-2020, 10:18 AM
ronjenx
ronjenx's Avatar
Originally Posted by NIUPonyBoy View Post
Which bold did you use? Iíve done a few bodge wires and ran a local ground to the bumper coupler to the frame. It works intermittently now at least. I want to fix permanently as it really pissing me off. Thanks.
"Which bold did you use? Iíve done a few bodge wires..."
I don't know what this means.
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
