D44 HD recieved - JeepForum.com
 2Likes
post #1 of 31 Old 08-13-2015, 01:27 PM Thread Starter
JTPhoto
JTPhoto's Avatar
D44 HD recieved
Buddy and I order the D44 HD PN P5160036 housings from MOPAR performance. They have arrived.
They have thick wall J8 tubes and heavier C's. All Rubicon parts are of course direct fit. Come complete with Balljoints and axle seals.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #2 of 31 Old 08-13-2015, 04:40 PM
ncb
ncb's Avatar
Are the brackets beefier and better welded?
ncb is offline
post #3 of 31 Old 08-13-2015, 05:29 PM Thread Starter
JTPhoto
JTPhoto's Avatar
The brackets definitely seem to be heavier. I will have a better look in the next few days and report back. The tubes and C's are definitely heavier.
^^Jeff^^
JTPhoto is offline
post #4 of 31 Old 08-13-2015, 06:17 PM
ncb
ncb's Avatar
Pictures comparing the two housings would be awesome if you have time.
ncb is offline
post #5 of 31 Old 08-13-2015, 08:07 PM
SLADE
What was price on the housing? I remember saying it was much cheaper than any other housing (Teraflex, Currie, Dynatrac).
Do you have an online link where you got it?
I'm interested and watching.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #6 of 31 Old 08-13-2015, 08:39 PM Thread Starter
JTPhoto
JTPhoto's Avatar
Originally Posted by SLADE
What was price on the housing? I remember saying it was much cheaper than any other housing (Teraflex, Currie, Dynatrac). Do you have an online link where you got it? I'm interested and watching.
MOPAR overstock was the best price at $865USD .... http://moparpartsoverstock.com/
I got mine from my local MOPAR Jeep dealer for $1400 cdn which works out about the same with exchange.
I will try and get side by side photos once the old unit is removed.
^^Jeff^^
JTPhoto is offline
post #7 of 31 Old 08-14-2015, 05:16 AM
SLADE
http://www.moparpartsoverstock.com/p.../P5160036.html
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #8 of 31 Old 08-14-2015, 12:03 PM Thread Starter
JTPhoto
JTPhoto's Avatar
Thats the one..
^^Jeff^^
JTPhoto is offline
post #9 of 31 Old 08-14-2015, 12:06 PM Thread Starter
JTPhoto
JTPhoto's Avatar
Ordered 2. One for buddy's Rubicon and the other for my Sahara.
^^Jeff^^
JTPhoto is offline
post #10 of 31 Old 08-14-2015, 12:23 PM Thread Starter
JTPhoto
JTPhoto's Avatar
Not sure if the Rubi D44 has it but these housings actually have a drain plug.. Once I get mine into the shop i will get some measurements on tube thickness and bracket thickness comparison..
^^Jeff^^
JTPhoto is offline
post #11 of 31 Old 08-15-2015, 10:19 AM
Rigger007
Are the Cs really bigger? Some of the info floating around said they were the same castings as used on the standard JKD44.
W7TJD
Help keep our public lands public
Rigger007 is offline
post #12 of 31 Old 08-15-2015, 02:25 PM Thread Starter
JTPhoto
JTPhoto's Avatar
They are definitely different. The new axle Cs have a smoother finish and a part number where the original housing Cs do not. In my original post the photo shows the PN on the C.
^^Jeff^^
JTPhoto is offline
post #13 of 31 Old 08-15-2015, 03:32 PM Thread Starter
JTPhoto
JTPhoto's Avatar
Cleaned off the Cs a little better on the factory axle and did indeed find a PN.
OEM #
Left side
6
J2L256
2003512
Right side
4
J2L256
2003512
On the 44HD
25
J2N571
2003512
As you can see there is a difference in the PN
^^Jeff^^
JTPhoto is offline
post #14 of 31 Old 08-15-2015, 06:55 PM Thread Starter
JTPhoto
JTPhoto's Avatar
Very cost effective build. This is what I have into it.
$865 D44HD housing
$1125. OX locker with electric actuator kit
$300 Yukon Gears and Master install kit
$335 Crown OE axles
Total $2625 USD.
^^Jeff^^
JTPhoto is offline
post #15 of 31 Old 11-11-2016, 10:16 AM
anditdi
Hello
I am sorry to revive this old thread to life but this is the only place where I read about a successful switch from a front D30 and from a Rubicon D44 axle to this D44 HD PN P5160036.
I live in Europe and I am tempted to switch my bent front axle with this D44 HD axle. I have a small question regarding the process, does all the Rubicon internals (especially front locker and carrier bearings) fit this J8 axle or it requires some modification.
I read mixed information about this P/N compatibility with front Rubicon's D44 Carrier Bearings.
On a Dynatrac's document where they compare all D44 axles it is mentioned that the front Carrier Bearings outside diameter for D44 is 3.313” (which is absolutely true) but for the J8 front axle the O.D. is 3.265” which will fail the locker swapping process.
Can you please shade some light on this matter because I don't know if I should venture and import this axle from US or not.
Thank you for your time and effort to share your experience with this,
Andi
anditdi is offline
