Changing Gears - JeepForum.com
post #1 of 7 Old 07-23-2021, 08:24 AM Thread Starter
DocAdams1
2016 JK Wrangler
Changing Gears
I am finally at the point where my jeep is just a toy and no longer used as a DD. I have decided to go ahead and regear to better support what I am using the jeep for.
I am going from the stock 4.10 gears to 5.13 gears. I have the 6spd manual and am rolling on 35x12.5 tires.
I typically turn my own wrenches, but am going to have the gears done professionally. I am just wondering if anyone is running a setup like this and what you like/ dislike about it.
My install is set for the 30th.
DocAdams1 is offline
post #2 of 7 Old 07-23-2021, 08:50 AM
222Doc
222Doc's Avatar
if it had 4.1 then it must be a rubicon. since no other Jks 12 and up had that unless a rubicon and that was a option too or they are all 3.73 rubis if a AUTO, your is stick so Rubi would be 4.1 stock. stock sports are 3.21. 5.13 is a lot of gear for 35s on a 16jk. will be spinning some rpm if it does need to go down road.
5.13 would support 37s, but then other stuff is needed.
my 12jkr is still 4.1 and i do run 37s and its hard trails, jeep is on a trailer as well. Off road the 4.1 gears and 4:1 low does rather well a bit more wheel speed when needed and still more then enough crawl ratio, but it is a auto 5 speed. I should regear for street as it tends to be a dog going up say 12% grades on street that one gets into on some trails getting there. Still faster the say my friends tjs on same tires but 5.13 gears.
222Doc is offline
post #3 of 7 Old 07-23-2021, 09:02 AM Thread Starter
DocAdams1
2016 JK Wrangler
Yep mine is a rubicon. I decided to stick with 35s this go around, went from 315s to 35s so 1/4 to 1/2" difference. Ultimately I will move to 37s, but like you said there is a bunch of supporting mods needed to do it right. I will just upgrade as things break or wear out.
post #4 of 7 Old 07-23-2021, 11:28 AM
cranbiz
cranbiz's Avatar
If your plans include 37's in the future, go 5.13's now.
My mistake was not knowing the future. When I did 4.56's, I was never planning on 37's (12, NAG1). Had 33's, knew I would go 35's. so 4.56 was correct. Fast forward 4 years, more into technical off road, won a set of 37's so that's where I went. Just not worth it for me to re-gear again.
02 WJ Laredo, heavily optioned but stock
12 JK, 3.5" Teraflex/Franken lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #5 of 7 Old 07-23-2021, 11:55 AM
222Doc
222Doc's Avatar
My mistake was back in 2012 when i bought this. Hindsight i would have bough a used buggy on 40s and one tons to start with. then just rebuilt that as i wanted would have been far less money and better off road then a jeep. sure you can buggy the Jk or any jeep but its never going tobe like a full tube buggy..
222Doc is offline
post #6 of 7 Old 07-31-2021, 10:33 PM Thread Starter
DocAdams1
2016 JK Wrangler
Just an update. The deed is done and I am in the break in phase. So far so good and I am enjoying the 5.13s. On 35s I am turning ~2600 @ 65.
post #7 of 7 Old 08-07-2021, 05:55 AM
krafty17
krafty17's Avatar
2017 JK Wrangler
After all my research, i just made an appointment to take my 17 Rubi from 3.21 (WTF??) to 4.88's. I have an auto and running 35X12.50's. I never plan to go 37's cause I want to ensure it fits in the garage.
krafty17 is offline
